1962
i agree with some of the previous posts. for some wood is not the way to go, especially if you have to buy it. if you already have a chainsaw, splitter, and dont mind some back breakin work, then money can be saved. i heat with wood with a add on wood/coal furnace. i have a log splitter and a saw or two. i dont have vast acres of hardwood trees, so i fetch it all year long.
some places i get wood: storm damage, local homeowner tree removal, construction sites, recent logging areas, and the local paper free ads. pretty much if i drive past a down tree or a pile of unsplit logs i stop and ask. 8 out of 10 times the property owner wants it gone, especially for free.
if i had to buy the wood, i wouldnt burn it, i would probably switch to coal. it's much cheaper. this work for the wood is free, but it is hard work. but there is nothing like wood heat, toasty warm through out the house. i run a large humidifier, its a real quiet one cause it runs alot. wood heat is real dry, and i heat with wood 24/7. i get about 8 hours between fuel loads, 6 hours when its in the single digits. the firebox takes a 26" log, and it takes about 8 to 10 large pieces to fill it. unsplit dry logs burn the slowest, and the best burning wood i have used so far is white oak, hickory, and locust. i have ben using this wood furnace for 7 or 8 years and have saved thousands of $$$. now fuel prices are going even higher and the savings will be greater. i bought this wood furnace used for $400.00. and it works great, though i put a larger blower and 220v motor on it..
