Tractorable
Veteran Member
- Joined
- Feb 15, 2017
- Messages
- 1,328
- Location
- Marshall, Va
- Tractor
- Tractorless, 2022 F350 Tremor, 24ft Diamond C HDT Equipment Trailer, 1980 Toyota Land Cruiser FJ40
Find yourself a socket about the same size as the outer race of the bearing to tap the new bearing into the gear box housing. Heat is your friend. If you need a little extra clearance, heat the gearbox housing with a propane torch prior to installing the new bearing. Do the same when installing the new lower seal.
That's how I've replaced bearing in hubs before. I would guess it'd be similar for the gearbox.
