RaydaKub
Veteran Member
I've got a red/black wire, a blue wire, and a black wire under the seat. As near as I can tell, the black is a ground, the red/black is the work light source, and the blue is the goofy HST warning light that isn't used in the US.
I am trying to add lights to my ROPS. I have only the little 6 inch pigtails on the new light and plugged those directly into the bare wires I found. I used my volt meter alligator clips to hold them together as well as take a reading. If the light is not hooked up, I get about 10 volts, but with the light (55 watt, so 4.2 amp draw) the voltage drops to almost nothing and there is no light whatsoever. The battery measures 12.5 volts.
If I hot wire the light using my jumper cables, it's like daylight in the garage.
Oh, and while it was hooked up, I couldn't turn the tractor off. I just found my red tip lever for the first time. But it didn't blow the fuse. After I disconnected the light, the tractor shut off just fine. :thumbsup:
Any advice out there? Should I just run my own wire and forget about this circuit? There's a fuse in the kit anyway, but this wiring is so handy. :confused2:
