X758 Overheats after an hour
   / X758 Overheats after an hour #1
Oconee1868
JohnDeere 4200 & John Deere x758 2017 4wd
My x758 will overheat after an hour of operation especially mowing heavy grass. Air filter Clean
   / X758 Overheats after an hour #2
Check the radiator screen and the radiator for debris. The screen does not stop it all. Also check your coolant level.
Dave
Dave
Thanks ... I keep the screen clean but I will make sure the Radiator is double clean. Coolant is full.
   / X758 Overheats after an hour #4
I take a air wand and blow thru the radiator from the engine side (reverse) every time after mowing.
   / X758 Overheats after an hour #5
Kubota L4600. Had to take radiator off due to a leak. I set it at 45 degree to clean it before I took it to the radiator shop. I always clean after mowing. I probably washed out a pint or more of dirt with the hose. Sprayed each side bout 3 times before it became clean. And this was after I cleaned it after I mowed. I'll know to do a better cleaning next time.
