I don't have a direct answer for the OP, unfortunately, but hopefully your dealer can help you figure it out. We haven't had any affected machines ourselves, but I did hear mention of an early unit that needed to have the EGR valve replaced....that thing not doing its job properly might lead to what you're seeing, so be sure to ask your dealer about that. If they don't know they can contact the LS tech adviser for their territory for help. A couple general comments I'll make based on some posts here.... Ozley is correct, the new XR3100 & 4100 series tractors just started shipping a few months ago....mid 2015, not 2014... I don't think dealers even had any inkling of a new engine in the works until mid to late 2014, and no technical details or projected price estimates were available until after April 2015, so there weren't any dealers holding out on new model info in early 2014....we weren't even a full year into the ISM equipped models at that point. These new LS engines are very different from the ISM motors in the XR3000 and 4000. The ISM engines are a fairly traditional motor on the injection side of things, so there's more particulate in the exhaust vs the new engines, and therefore a 4 hour cleaning cycle for the filter. The ISM engines are high tech in a lot of ways, so don't think of them as an "old" or "outdated" design necessarily ...they just use a less costly method of achieving Tier 4 compliance. The LS engines use a Delphi common rail (CRDI) injection system that is very advanced (amazing really!)...the short version is that they have computer controlled electronic fuel injection that's operating at roughly 26,000 psi (piezo electric injectors are crazy!!....google it...there are some neat videos that explain it. Is this evidence of alien technology being shared with humans? Maybe ;-). The injectors can do 2 micro pulses before the main fuel charge is injected, and 2 more pulses afterwards (so 5 injector pulses total per combustion cycle) to insure very complete combustion of the fuel, which is getting atomized out the wazoooo at those high pressures. If fact, there's actually exhaust regen taking place in the combustion chamber thanks to the EGR valve and the final 2 injector pulses introducing a bit more fuel to burn any uncombusted diesel and maintain proper temps. What you end up with is an engine that makes more power on less fuel (11% fuel economy boost vs the ISM motors is what was quoted) and has exhaust that's clean enough to not require an afterburner at all to meet the regs.... as it was described to me, LS wanted to have the cleanest exhaust of any tractor engine in existence, so they included a simplified afterburner on a 50 hour cycle to give them those bragging rights. Bottom line...we've been really impressed with the ISM engines and expect them to be one of those "lifetime" motors, given proper maintenance. But the new engines are very advanced and offer the advantages of more power per unit of fuel, with cleaner exhaust even before it gets to the DPF, and a 50 hour reburn cycle instead of 4.
