Underwaterdog
Bronze Member
I remembered reading about something similar to this on the board, so I did a search for power loss under yanmar. It is gravity feed isn't it? If so, it is unlikely that the fuel bowl could be sucking air. There have been some issues with the plastic fuel bowls shrinking and leaking, but none that I recall sucking air. As far as the vent is concerned, we learned from one of Kenmac's post that the tank will implode if it is not vented. So the only way I can figure it to suck air would be if the tank is not vented and a leak developed in the lines or the bowl. I remembered reading about something similar to this on the board, so I did a search for "power loss" under yanmar.
Here is one thing that I found under "Loss of power in YM1700":
Trying some different search terms will give different results , but my guess is the answer is already somewhere on this board.There were several suggestions, but they didn't post the fix. So please, when you do locate the problem, and I have faith that you will, give us the answer.
Originally Posted by jkelley8
I had a similar problem. It turned out to be a bend in the return fuel line sending the unused fuel back to the tank.
Had major loss of power most especially in the higher range gears.
