Check for voltage with a volt meter. Harborfreight has them cheap if you don't have one. Should be 12volts to ground at the large cable on the starter solenoid. Could be dirty connections, bad cable, dead battery etc. When key is turned you should see 12volts on the small wire at the starter solenoid.
