CoyPatton
Veteran Member
- Joined
- Aug 10, 2015
- Messages
- 1,482
- Location
- Poplar Bluff, MO
- Tractor
- Yanmar YM2002D with Koyker 110 FEL
I know little to nothing about tractors. I understand that if I am honest and tell it straight up, that people are more forthcoming with info. Im just a guy who used to live on 2 1/2 acres and moved to Idaho on 175 acres of intermediate wheat grass to be left alone, raise his own food and stock his pond with bass, bluegill, catfish and live out his days.
I know this little tractor isnt going to do everything I need but its a start and all the $ I had. After 30 years of police work Im living off of a small pension and money will now always be tight. So slow and steady is now the rule.
OK, the tires are 'ricer tires" ???? That I didnt know. And the fronts have multiple cracks in them too. So my rancher buddy told me a while back that Les Schwab comes up once a month and does mobile tire work on ranches. So if I was going to get new tires that are ideal for ranch work, lots of post hole fence work, moving some dirt, garden work, grass cutting (both of those when I can afford the attachments) what would a nice set of four tires be and what do you think they would cost? Im very open to learning.
RUMBLON
With tubes in your tires and the relatively slow speeds you will be working at, you will probably have years and years and years of life in your cracked tires.
Front tires if you use lots of 4x4 and loader work you may need to replace due to worn out tread. More likely in my opinion is you will run over a portion of a limb and ruin a tire than having issues with the cracks as long as the tires have tubes.
As for ‘ricers’ (R3) as compared to R1 tires, the more air pressure, the more the tire will ride on the lug. The ride on hard surfaces will also be less comfortable with higher air pressures. As for traction, that is why you have different types of tires. To say ricers provide less traction when they are designed to be used in muddy sloppy race paddies, is kin to saying 4x4 provides less traction. Match your tire type to the type of work you typically will use the tractor for and accept that you will give on other points. (For example, if mowing a yard is your largest usage get turf tires, realizing that you will not have the traction in loose soil that ag’s would provide)
