franklin2
Gold Member
I thought it could not be done. I have seen people try to weld cracked steel hydraulic lines on tractors, forklifts, backhoes, etc. and they never were successful.
So, we had a skid steer with a backhoe attachment. It had steel lines running up the arm, with hoses at the flex joints. One of these metal lines cracked and fluid was going everywhere. My Dad took the line off and went to a machine shop where he thought they could make another line. When we got there the guy smiles and said "oh, I got a guy who can weld that". I thought to myself no way. A young boy came out, took the line, adjusted his mig welder a little bit, welded the line and then gave it back. $20 later we are on our way, and I looked at the line, he had run a bead right over the crack. Installed it and it worked great. I was floored, as many times as I have seen this tried, and have tried it myself, I could not believe it worked.
A couple of weeks ago I had the A/C compressor clutch fly apart on my mini van, and one of the flat springs came around and was hitting one of my steel refrigeration lines, cutting a little hole in it. Encouraged by what I saw on the hydraulic line, I got my mig out, cleaned the line really good, set the amps low, and welded it. No burn through or anything. But it had a pinhole leak. I welded it again. Pinhole leak. Frustrated, I smeared some JB weld over the welded area, and it has held ever since. But I am bummed out that I could not weld it and it be leak free.
What is the trick to welding these lines and they be leak free? I know it can be done now.
P.S. I posted this question also in the build it yourself section. Here's a link.
http://www.tractorbynet.com/forums/...-what-trick-making-leak-free.html#post3869641
