Front differential vent
   / Front differential vent #1
Car Doc
Elite Member
Kansas
YM3810D Yanmar
I have noticed every time I check my front diff lube there is pressure behind the plug.
Since Scotty Dive has been working on his 2020D front end it reminded me of the add on vent I added to fix that particular issue here is a couple pics for anyone experiencing a similar problem.
A 1/8 pipe barbed hose nipple fits it isn't the exact thread but it goes in fine as far as it needs to go.
I have a slight 90w leak at times from the front diff coming out the drive shaft tube at the front and I believe this will slow it down maybe even stop it time will tell?
   / Front differential vent #2
I've noticed pressure/ suction on mine as well.If I had a tap (like yours)I would add a vent line. I would have to drill & tap a hole for a vent
Oh heck I just figured all of these had them thats why I started this thread and especially one like yours which is the same tractor as mine.
I sure would have thought they would have drilled and tapped all of them as well engineered as these are overall learned something else new today!
2020 Broyhill Load and Pack Articulated Solid Waste Handling Vehicle (A59228)
2020 Broyhill Load...
2017 Toyota Camry Hybrid Sedan (A59231)
2017 Toyota Camry...
2015 CATERPILLAR 815F2 SOIL COMPACTOR (A60429)
2015 CATERPILLAR...
2021 CATERPILLAR 306 CR EXCAVATOR (A60429)
2021 CATERPILLAR...
2022 FREIGHTLINER M2 26FT BOX TRUCK (A59905)
2022 FREIGHTLINER...
Freightliner Tender Truck - Adams Tender (A61307)
Freightliner...
