California
Super Star Member
- Joined
- Jan 22, 2004
- Messages
- 14,680
- Location
- An hour north of San Francisco
- Tractor
- Yanmar YM240 Yanmar YM186D
If that anchor pin isn't near square then I wonder if the wrong pin was put in there by someone. It should be slightly wider in one direction.The top pin that the shoes rest on is not designed to be turned how I see it. The shaft has flat sides on the opposing sides if you turn it 90 degrees but the surface they rest on is not near as large as the way its designed to be inserted. that and mine is stuck and I will have to get it back in a vice and possibly heat and beat to get it out.
Any suggestions, I measured my drum and its right in the middle of the spec in diameter so its not worn out or turned down to far.
Here's a trick I discovered on an old car when I opened it up: Someone had welded additional metal on each end of the brake linings to make them expand farther. Then ground and polished the weld blobs so they wouldn't gouge the cams. If your shoes are near the wear limit this might give you a few more years.
Something else that might work: cut more threads on the adjusting rods if they don't already bottom out.
But I think new brake shoes and likely anchor pins are what's needed to do this right. It sounds like you have reached what Yanmar designed as the wear limit.
