Case Farmall 60B
Model Year: 2013
I purchased this tractor 6 months ago primarily as a slasher and fencing aide. I added a 4in1 bucket/loader, woods 5-ft. heavy duty slasher, and an auger torque hydraulic earth drill with 200mm auger. The 5 ft slasher enables full power transfer and haven't encountered neck high thick grass that can't handle. Was advised against a 6ft slasher and am happy I listened. The auger is mounted on the FEL and controlled with 4in1 bucket joystick. Our property is very hilly and the loader mounted auger allows greater flexibility in positioning. Also being able to reverse the auger direction is useful in rocky ground when jams. Have dug 400+ post holes so far and going well. The operator deck is well designed and comfortable to use. 4 range x 4 speed gears (16 forward & reverse), with shuttle shift forward/reverse change makes maneuvering simple. This is my first tractor purchase and haven't had any regrets.
Pros: Excellent value package.
Cons: None.
Photo Uploads:
