Case-IH 885_2 Reviews
4.00 star(s)
stech64
885_2 Case-IH
885 MFWD
Model Year: 1990
This is a great tractor. It likes the taste of diesel. We have clutched it three times in its life. It has 6,500 hour on it and now pulls a 15 foot bat-wing and our 5x6 baler, besides moving all our hay. It is a good workhorse!
Pros: Would buy again
Cons: Uses a lot of fuel
4.00 star(s)
bfg
885_2 Case-IH
4* All Round
Model Year: 1990
I've given this tractor 4* all round because I dont have it a week yet but so far I like it. Case-IH 885xl 4 wheel drive. The cab is comfortable enough though I think once I start traveling the roads more it will be bouncy in there. Great starting. Hydraulics seem strong and capable although a bit slow. It looks good and sounds good but only time will tell.
Pros: 4wd, good visibility from cab, cheap to buy, small turning circle for tight yards.
Cons: Slow road speed and slow hydraulics.
5.00 star(s)
Anonymous Poster
885_2 Case-IH
Problem Getting Stuck in Reverse
Model Year: 1986
Hi, can you please help me? I've just bought Case 885xl tractor and it keeps getting stuck in reverse?Can anyone help or may have solution for me to this problem? Thank you. Thomas
Pros: Good tractor.
Cons: Problem with gears.
5.00 star(s)
gregsrepairservice
885_2 Case-IH
18 Year Review
Model Year: 1988
This tractor has been exceptional. The only little things that came up: Hydraulic problems were made big by a case dealer that did not know how to fix. When I found a good dealer 150 miles away, it has been perfect ever since. Had o-ring in brakes replaced twice and 3 point hitch worked on once. Other than that, batterys and one starter. I put over 1000 hrs on tractor my self.
Pros: With MFD, very hard worker.
Cons: A little heavy. Maxes out 7,000 lb trailer with implement.
5.00 star(s)
THOMASMILLWARD
885_2 Case-IH
Case 885 XL 4WD
Model Year: 1987
A fantastic tractor. It's great fun to drive and never a dull moment when I'm in the machine, it has the XL cab which I find much better than the L cab when using a loader as you are sitting below the bonnet with the L cab, it has a Quicke 430 loader, a reliable workhorse that would do anyone proud.
Pros: Reliable.
Cons: Needs greasing quite often.
Photo Uploads:
4.00 star(s)
pitotshock
885_2 Case-IH
Case 885xl
Model Year: 1987
Good used tractor. Have the cab and 2255 loader and triple remotes. The cab has a bit too much rust for its year because it lived some of its life as a snow blowing tractor for a landscaper and we use salt up here. Runs well, no glow plugs so a good block heater is in order to start it when below freezing. Strong and does just about everything I ask it to do, from moving earth and manure to hauling logs and full sized trees on the forks
Pros: Dependable
Cons: none really
Photo Uploads:
