Hilbilly
I've looked into getting a Lane Shark, TB-One or Limb Ninja to use for maintaining the sides of our long driveway, the even longer fence line and the trails on our property but there were some things I didn't like about some of the offerings plus the price. When converted to $CAD they were a lot more than I want to spend. So I decided to make one myself. I already have a hydraulic power pack I built for my converted 3PTH snowblower plus the hydraulic motor I use on the blower. All I needed was a used 4ft brush mower. I couldn't find anything used anywhere near us so I bought the cheapest new one I could. Here are some pics of the beginning of this project.
1st is the new mower before any work started
2nd, 3rd and 4th are the adapter I had to make to attache the hydraulic motor to the gear box. The motor side is 1" diameter with a keyway and the gear box side is 1 3/8" with a 1/2" shear bolt
5th was the operation I feared the most. Marking out the radius for the cut and trying to get a smooth cut. Sure was reluctant to cut up that nice new mower.
6th shows the reinforced lip I made to strengthen the cut edge of sheet metal. I used the 3PTH support braces for the material and slowly formed the radius using a hydraulic press. Tedious work.
7th is the homemade hydraulic power pack. The pump will produce up to 37gpm at 2400 rpm. I built a gear and sprocket setup to increase the 540 PTO rpm to 850 rpm to produce up to 20 gpm.
8th is the temporary setup on the FEL 3PTH adapter I made for the snowblower conversion. I just wanted to see how it performed before I started on the mounting system to offset the mower and tilt it.
It worked well and now I have to figure out how to set up the mounting system. I would like the following features;
1 mounts on either side
2 mounts in center
3 has hydraulic side tilt for moving from below horizontal to vertical.
2 mounts in center
