dstig1
Super Member
- Joined
- Apr 7, 2010
- Messages
- 5,706
- Location
- W Wisc
- Tractor
- Kubota L5240 HSTC, JD X738 Mower, (Kubota L3130 HST - sold)
I added a 3rd function to my new tractor. I did it before on my L3130, so I knew what needed to be done, but the new L5240 has a different setup for the hydraulics that made it a bit harder to do. That mostly just meant more expense in the hydraulic lines/fittings. Such is life.
Here are the implement connections. I used 3/8" steel and painted to match, using the same point Kubota does for the factory 3rd function. Also the same basic place it was on my last one. Bulkhead hydraulic fittings attach it to the plate.
I made the brackets to hold the hoses to the existing clamp points on the arm. The brackets come welded on from the factory - I didn't do that. I bent and painted the clamp to fit from 1/8" x 1.25 steel. This shows those and the hose runs. The pic above shows it a bit too.
And buried back in there (above) is the diverter valve. I screwed it to the FEL upright rather than clamping it onto the arm. That was largely due to a suggestion from Brian at Fit Rite Hydraulics (where I got the diverter and joystick switch), plus it was almost necessary to put it there due to the differences I noted above.
That is the hydraulic side.
