Snowblower skid shoes digging into gravel
   / Snowblower skid shoes digging into gravel #1
Steuny
We have had little snow and the ground is not frozen. My snowblower shoes are digging into the gravel on my driveway with this mornings 4" of snow. The obvious solution (in my mind) is to increase the size of these shoes. Are there any other ideas that work better. How big would these shoes need to be?
Has anyone else experience similiar problem and how did you solve it.
   / Snowblower skid shoes digging into gravel #2
mushroom shoes free to rotate ...like snowplow shoes
   / Snowblower skid shoes digging into gravel #3
Evening Steuny.
"the ground is not frozen"...not real much you can do others than maybe lower the blower so the shoes just barely touch the ground....down side of doing this not nice looking clean job,also extra weight from the blower on wheel bearings.
   / Snowblower skid shoes digging into gravel #4
I put 6" narrow wheels on mine in place of the skids as soon a I started doin g snow on gravel. They work well. Snow packs inside them against the frame until you figure out the right fender/guard arrangement. After that, trouble free on any surface.
Larry
   / Snowblower skid shoes digging into gravel #5
I slit a steel pipe and put it over the full width of the bottom lip of the blower. I posted a (not very good) picture of this on a thread that's going right now on the Kubota Owning/Operating board. There is some other good info in that thread. I'd post a link to it if I knew how :confused: , but the title of the thread is "Rear 5 ft. snowblower questions about using". Good luck.
   / Snowblower skid shoes digging into gravel #6
I have a friend who went the wheel route and said they work great.
   / Snowblower skid shoes digging into gravel #7
I put lawn mower wheels on mine. If I get a chance later I'll take a picture of it to show you. Works great on my gravel driveway.
   / Snowblower skid shoes digging into gravel #8
As promised, pictures of my lawn mower wheels on a snow blower. I also used the lawn mower wheel adjusters. Instead of digging into the gravel and ground they just roll over it. Also works great in my back yard to make a path to the garage. They just roll over the grass/lawn without digging in.
Thanks so much for all the useful replies. The slitted pipe may be a good solution for me. My front mounted snowblower weighs about 350 lbs and the wheels as pictured above may still dig into the gravel. I have asked SPYDERLK to post or e-mail me a picture of his wheels before I go the pipe route. Thanks again for all the replies. I did go to to that article you mentioned and it was informative.
   / Snowblower skid shoes digging into gravel #10
Thomas said:
Evening Steuny.
If you lower the blower prior to the ground being frozen the snow blower will pick up a bunch of gravel and you will have to rake it out of your lawn come Spring before you do any mowing. Don't ask how I know.
The wheels look like a good idea, maybe I will give it a try myself.
David B
Redirective Crash Cushion Guardrail (A51692)
Redirective Crash...
1997 Freightliner FL60 Truck, VIN # 1FV3GJBC6VH725847 (A51572)
1997 Freightliner...
1996 JLG Commander CM2033 20ft Electric Scissor Lift (A51691)
1996 JLG Commander...
Echo SRM2620 Gas Trimmer (A52377)
Echo SRM2620 Gas...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A52576)
2019 INTERNATIONAL...
2019 TEREX PHOENIX 2100 TROMMEL SCREEN (A53426)
2019 TEREX PHOENIX...
