What's Good Grease for a 5th Wheel
   / What's Good Grease for a 5th Wheel #1
Iplayfarmer
Super Member
Idaho
Massey Ferguson 1215, Case 801B
I just got a 5th wheel trailer that included the hitch. I had the hitch professionally installed, but now I have a question about the plate.
What kind of grease is good to use on the plate, and how often should I grease it?
   / What's Good Grease for a 5th Wheel #2
My first post, hope I can help.
I quit using grease on my 5th-wheel plate in favor of a Teflon disc. Much cleaner, and works like a dream. Should be available at any RV store.
   / What's Good Grease for a 5th Wheel #3
Teflon disc all the way. Also referred to as a "lube plate".
Okay, how does it work? Does it just snap in over the current plate, or do I need to modify the hitch somehow to make it fit?
   / What's Good Grease for a 5th Wheel #5
No mods, it snaps over the pin on your trailer.
Mine is about 5 years old and not worn down enough to warrant replacement, though I don't tow it more than about 5,000 miles a year.
   / What's Good Grease for a 5th Wheel #7
The lube plates work great and are clean.
I just can't use one on my binkley head:(..... grease still works.
   / What's Good Grease for a 5th Wheel #8
Has anybody tried Slip Plate aerosol graphite? Yould have to reapply between use occasionaly, but its dry and clean.
larry
   / What's Good Grease for a 5th Wheel #9
So what are you disk guys using to lube the pin and hitch jaws? There is more to this than just the plate lube. I figure if I need to grease part of it I will grease all of it. And to the OP, any good EP grease seems to be good. Back in my days of driving the big ones the fifth wheels just got chassis lube and it lasted just fine.
   / What's Good Grease for a 5th Wheel #10
I would hope everyone is greasing the moving parts and the pin.
The lube plate just cuts down on dirt collection for the RV fiver. Commmerical is a little different. I wouldn't think a lube plate would last too long on a commercial rig.
2004 INTERNATIONAL 9400I DAYCAB (A55745)
2004 INTERNATIONAL...
2014 Ford F-150 4X4 Ext. Cab Pickup Truck (A53422)
2014 Ford F-150...
2003 Big Tex 10PI...
2019 INTERNATIONAL 4300 26FT NON CDL BOX TRUCK (A56138)
2019 INTERNATIONAL...
RoGator RG1100C (A55302)
RoGator RG1100C...
2019 CUMMINS CM20-1 PORTABLE SKID GENERATOR (A55745)
2019 CUMMINS...
