cultivator, disk, or spike harrow
   / cultivator, disk, or spike harrow
Sounds like a disk may be my best option. Will I also need some type of drag harrow behind the disk if I am only disking "lightly"?
Some disk appear to have notched blades on both the front and back and others have notched blades only on the front set. What difference does this make?
I originally was shying away from buying a disk since I already have a tiller.
Steve
   / cultivator, disk, or spike harrow #12
Probably not. But, if you disk heavily, then seed, you might need a drag harrow to lightly cover the seed. I've gotten good results (cow peas, sorghum, sunflowers, oats, etc) by disking heavily (usually after plowing), then broadcasting then disking with the disk gangs straight and not using a drag harrow at all. YMMV.
I've ben told that notched disks are better for chopping clods and turf etc. All the disks on mine were notched and they seem to work well. I've seen disks where they are all un-notched. Others mixed. For most of us it probably makes no difference.
Steve
They do similar things. A tiller almost certainly 'tills' better and is great for smaller areas. A disk can cover a lot more ground a lot faster and in general you can probably find more tasks to do with a disk.
I think a disk will serve you well, but definitely consider all the responses you've gotten here.
   / cultivator, disk, or spike harrow #13
sedmond, agree with N80 very much.
The notch blades are for crop trash. Crop trash will get caught in the notches and get cut where often will just keep being pushed by the round blade. That is why you see them on the front and round on the if you see both on a disk. The more trash you have the more valuable they are. As to clods, no idea there. If the dirt were right clean think you get more complete cut with the round blades as you get the full depth all the way around the blade.
   / cultivator, disk, or spike harrow #14
When I worked on the dairy we would overseed our pastures every fall, about 300 acres worth. We would adjust our harrows so that the disks were straighter, then we would broadcast the seed and lightly disk over it pulling a drag behind the disk. We too have classic red clay but in the fall we would have to keep the wheels on the ground to keep the disk from going in to deeply. Of course we were using a pull disk which has more weight on the disks but I have done this also with my 3pt disk with good results.
   / cultivator, disk, or spike harrow #15
Here is a little unit I have on order and looking to do very similar things you are looking at doing.
Aerator Products
I'm thinking I will either disk or use my scarifier to lightly scratch open the dirt.
   / cultivator, disk, or spike harrow #16
oops.. its the Ferguson 3pt yardmaker.. just realize the link had several pieces of equipment on it. darn mouse clicking.. it does what I tell it to do and not always what I want it to do..
   / cultivator, disk, or spike harrow #17
you're not gonna grow sqat after discing and waste your money on seed. good luck.
your question is like this one, i have a hammer are screwdriver and a pocket knife, which one is the best to mine salt with?
use the right tool for the right job.
   / cultivator, disk, or spike harrow #18
You might be right, but no more likely to be right than anyone else who has answered so far. I have done what he is talking about, using a disk. Not only did I get a good yield (although it was not clover) it also did not significantly damage the existing grass. When a disk is set with the gangs out straight, it does little more than put a long grove in the ground. It does not go deep and does not move much dirt. It does not 'turn' any sod.
That's correct. So why would someone then answer that he needs a $100,000 saltminer? He has what he has, or what he can resaonably aquire. Which of those is best?
A no-till drill would be the right tool for the job. If he can rent one and if his tractor can pull it and if it can handle his soil, then that would be a good option. But those are 'ifs' that he has to answer, not you or me. And, when he's done renting it, he has nothing to show for it but the crop. If he gets a disk or a cultivator then he will get years of additional use from them.
   / cultivator, disk, or spike harrow #19
There's a whole bunch of us old farmers who've re-seeded pastures and hayfields by discing, broadcasting seed, then cultipacking, and done so with amazing success for a bunch of years. I'd question your knowledge and reasoning for making a statement of "absolute" nature, knowing full well myself that it WILL work in most cases.
There are BETTER alternatives in some instances, IF available and IF afordable and IF conditions are right. But often the BEST alternative is the one you can afford.
   / cultivator, disk, or spike harrow #20
Those who say there are better options available than the three you have described are correct. However, as noted by FWJ, we often have to select the best option that is reasonably available to us. As far as I am concerned, the best option would be to HIRE SOMEONE to spray the pasture with Roundup, wait a few weeks until the weeds and grass start to grow again, spray with Roundup again, wait a few more weeks and spray a third time. Then hire someone to plant grass and clover with a no-till drill. Wait for the mixture to grow and pay someone to raise your goat and do all of the other work that needs done around your farm/home while you enjoy your family, friends and life in general. However, that isn't an option that is available to most of us.
To answer your question, I believe the disc harrow would work best. Like FWJ, I have reseeded a lot of ground with a disc harrow. I wait until the ground is moist enough to expose some soil by disturbing the ground ever so lightly. Straighten your discs out while using the disc - a little angle goes a long way. Then broadcase your seed and cultipack. It works very well and should not damage your grass; provided you do not try to do this during the heat of the summer.
You have indicated that you have Alabama clay and plan on planting white clover. Keep in mind that white clover does better in bottomland or areas that do not dry out too much during the summer. Red clover is a perennial that you might want to consider depending upon how much soil mositure you have throughout the year. The down side of red clover is that it will not likely last as many years as white clover.
Kubota 24in Quick Attach Compact Excavator Tooth Bucket ONE PER LOT (A51039)
Kubota 24in Quick...
2015 Freightliner Ambulance (A50323)
2015 Freightliner...
2015 KENWORTH T800 MID-ROOF SLEEPER (A50854)
2015 KENWORTH T800...
2015 Jeep Compass AWD SUV (A50324)
2015 Jeep Compass...
IF YOU BID ON AN ITEM YOU MUST PAY FOR IT!! NO BACKING OUT AFTER IT IS SOLD!! (A50774)
IF YOU BID ON AN...
Ford Super Duty 8ft. Truck Bed (A49346)
Ford Super Duty...
