Block Heater Question
   / Block Heater Question #1
Charlton John
Gold Member
North East New York
Kubota B2620
Hi, I have searched the many other posts on this topic and couldnt find the answer to my one question. My tractor came w/ a block heater that I have not used yet. I have also never used a block heater on the 2 tractors I have owned. Is there a way to tell its working after you plug it in, sound etc...? I just want to make sure when I do use (this weekend) I have a product that works. Thanks Guys!
   / Block Heater Question #2
Sure, when you go to start your tractor it starts right up running smooth:). Really though it your tractor hasn't been run plug it in and after about 15 to 30 min. put your hand in the area of the block heater, it should be warm. Other than that I haven't seen any type of indicators on any of the block heaters I've seen.
Good luck.
   / Block Heater Question #3
Many times after first plugging in heater, you will hear the cold water in block hissing from the heat element warming the water very quickly. Also, the block around heater will be warm in a minute or so. If block does not get warm to touch, chances are your heater is not working.
   / Block Heater Question #4
I'm assuming you have a factory type block heater, where you can follow the ac power cord to a point somewhere on the side of the engine.
In which case you should be able to feel some warmth around that area as well as other areas of the block after an hour or two of it being plugged in, In the immediate area of the heater you should feel it sooner.
Most people use some type of a timer so the heater goes on a few hours before anticipated use of the tractor, so you don't have to have it on all night.
Good Luck,
JB.
EDIT: I'm a slow typer and did'nt see you had a couple of good answers while I was responding.
I didnt use the tractor at all from mid Nov. till this past week. Then I needed to get her out to start moving all this snow around. I made sure battery was fully charged, clutch left disengaged and fuel was properly treated. The tractor is stored in a barn (new) so although not heated pretty air tight. The temps here have been very cold (only 1 day this month above freezing) The first day I cranked her up it was about 27 degrees and it fired right up no problem, (about 10 seconds on the glow plug) The second day I fired her up this week it was only about 10 degrees and although it started right up it seemed to start rough and sputtered a little. So I want to play some more tomorrow were we are only expecting highs of around 10 so I figured if I have the heater I might as well take advantage of it and use for the first time, thanks for the replys!
   / Block Heater Question #6
If it's quiet when you plug it in you should hear a few ticks and some hissing from the element warming up. If you leave it for an hour the engine will be fairly warm to the touch. After three or four hours the engine will feel like it has just been running. The Kubota block heaters are plenty big for the small size block and coolant capacity so warm up quickly. I seldom plug mine in for more than an hour on the coldest days.
   / Block Heater Question #7
startings only half the battle, as many posts here show ...you want to make sure your fuel won't gell and, if you haven't used it since early fall, chances are you don't have a winter blend in the tank ...so, I would treat the fuel with an anti gell additive ...and I would keep a spare filter or two on hand
Fuel has been properly treated # 2 deisel w/ treatment added. So I should hopefully be all set here. Thanks for the heads up
   / Block Heater Question #9
There are two ways to test a block heater. One is a device by JJeb company who manufacture's block heaters. You plug it into the power cord then to the block heater. If the block heater is good a light will come illuminate on the test device. The other way is use a ohm's meter and check for continuity across the the blades of the block heater plug(not the ground stud). If you have a open circuit the block heater is not good.
   / Block Heater Question #10
Could also use a Kill-A-Watt electricity usage monitor, if you had one.
JB.
2016 Hurricane Blo-Vac X3 Stand-On Blower (A50324)
2016 Hurricane...
2015 Peterbilt 320 Garbage Truck (A52377)
2015 Peterbilt 320...
2019 Allmand Bros Maxi-Lite II 20kW Towable Light Tower (A52377)
2019 Allmand Bros...
Cub Cadet Kohler mower 7000 series (A50324)
Cub Cadet Kohler...
2013 Ford F-550 Ext. Cab 4x4 Auto Crane 6406H 6,400LB Crane Service Truck (A53422)
2013 Ford F-550...
2018 PRINOTH PANTHER T14R ROTATING CRAWLER DUMPER (A52705)
2018 PRINOTH...
