Acres per hour to bush hog?
   / Acres per hour to bush hog? #1
queen of spades
Hi how many acres per hour should I expect to cover with a 4' bush hog and a 20hp diesel compact?
thanks.
   / Acres per hour to bush hog? #2
Around 2 if conditions allow you to go about 4mph.
   / Acres per hour to bush hog? #4
I think it would be just over 1 acre per hour
   / Acres per hour to bush hog? #5
thanks.
Width of cut in inches (Not including over-lap) X MPH, divide by 100
so, 48" mower with reasonable amount of overlap, let's say 40", 4mph, you may get as much as 1.6 acres per hour.
   / Acres per hour to bush hog? #6
Depends upon what your cutting and how fast and how good a job you want!
If you don't care shift up and cover the acerage !!
   / Acres per hour to bush hog? #7
Over the years I have studied and done all the calculations and the only certainty is that it always took longer than I figured.
   / Acres per hour to bush hog? #8
Yeah,and it always costs more than you thought it would.
   / Acres per hour to bush hog? #9
thanks.
With my 2005 Kubota B7510HST (21 hp engine, 17 hp pto) and a 4-ft King Kutter medium duty hog, I could cut about 0.5 acre/hr in 3-4 ft tall pasture and about 1 acre/hr in 1-2 ft tall stuff. Every few hours I'd have to stop and clean the trash off the screen in front of the radiator.
   / Acres per hour to bush hog? #10
Interesting, the excel sheet I made a while back says 1.69 acres/hour for a 4' cutter. It's nice to get confirmation from an expert!
jb
2017 Ford Explorer AWD SUV (A56859)
2017 Ford Explorer...
2018 ARIENS Zero Turn Mower (A56857)
2018 ARIENS Zero...
202474 (A54757)
202474 (A54757)
2021 Unverferth 432 Rigid 4 Row 36-inch 3PT Ripper Bedder (A55315)
2021 Unverferth...
2018 Ford Fusion Sedan (A56859)
2018 Ford Fusion...
