New to site. Need some expert buying advice
   / New to site. Need some expert buying advice #1
sloretto
CT
Hello Everyone!
I am looking to buy a riding mower tractor for a 1.5 acre property. My wife and I are expecting our first child in august and decided to move out of the city to the burbs in CT. I always wanted a riding mower and have been looking into purchasing one. Have checked out Cub Cadet, Husq, Craftsmen, Arien, and some others.
I am hoping someone can give me some buying advice. My budget is $1500.
Thanks!,
Stefano
   / New to site. Need some expert buying advice #2
In that price range,they are all the same,just different names and colors,so go buy the cheapest one.
Now if you wanted to spend 3-5 thousand,you'll have more meaningful choices.
Not an expert by the way.
   / New to site. Need some expert buying advice #3
"In that price range,they are all the same,just different names and colors,so go buy the cheapest one...."
While some will argue up and down against that, I totally agree. Not much difference in most of them except for the price tag.
Three years ago I was looking for a rider and spent some time checking all the different makes out. Dad had bought a 20hp JD riding mower a few years ago so I was familiar with their product but it wasn't all that much more impressive than the 18hp TroyBilt (MTD) that I bought for $1k at Lowes. Three years on I've had to replace the blades 3 times (rough lot, put severe duty blades on this last time and they are great) and a new battery this spring. Otherwise, couldn't be happier no matter how much money I would have spent. We have a one acre lot that gets cut 2-4 times a month 8 months out of the year so it's seen a fair amount of use and held up very well.
thank you for the advice. I was tempted to spend more $$, but I realize i have small yard with seasonal cutting needs, so can't really justify the expense of better quality mower. Thanks again!
Stefano
   / New to site. Need some expert buying advice #5
Stefano
Four years ago a bought a Huskee riding mower with 42" deck from Tractor Supply for $899. At the same time I bought a 4-year service plan from TSC for $125 or so. This is the 5th season. No problems with the mower. I did use the service plan once to have an electrical problem fixed (battery not fully charging). No cost. Now I just keep the battery on a trickle charger. Works fine.
No need to spend thousands on a JD, Toro or other expensive mower unless you go for the snob appeal. I figure if I get 5 or 6 seasons out of that Huskee cheapie, I'll be money ahead.
   / New to site. Need some expert buying advice #6
Not An Expert...But my story/ backround is alot like yours so I wanted to throw my 1 Cent in. (I dont even know enough for 2 cents)
Not to repeat everyone, but I recently did the research, and I tried to work within a 2000 budget. It was tough, I ended up well above that.
but to stay in your range, I don't know much more than craftsman that will be a good buy. Stay away from extra bells and whistles, look for Engine / deck size to be a good deciding factor.
If you are just mowing a lawn, the options are meaningless. I'VE heard that the "John Deere" sold at Home Depot are not worth the $$ b/c you are buying the name (when in reality those are below grade to be called a "DEERE")
Good Luck with Baby/Wife and Tractor.
   / New to site. Need some expert buying advice #7
If you are just mowing a lawn said:
I can attest to this on my last property (just under an acre) I bout a JD from Home Depot for over 2k. Nothing fancy just buying the name, (didnt know any better at the time) + this was my first riding mower. My neighbor at the time had a Craftsman rider from Sears and spent about 900 on his new and there was really no differnce in the tractors except the name and the deere had a bagger that could have been purchased seperatly (for another 3 hundred) I agree w/ others in this price range not really much of a difference. Good Luck
   / New to site. Need some expert buying advice #8
Thought about used? Might be able to get a slightly used quality tractor versus a not so great new one in your price range. :eek:
   / New to site. Need some expert buying advice #9
The BEST deal on a BBS Tractor is the one with the lowest price .
2010 LOAD MAX 40 FOOT GOOSENECK (A53843)
2010 LOAD MAX 40...
FECON SKID STEER QUICK ATTACH HYD MULCHING HEAD (A51406)
FECON SKID STEER...
2019 Ford F-550 4x4 Ext. Cab Chipper Truck (A51691)
2019 Ford F-550...
2014 DODGE CHARGER (A51406)
2014 DODGE CHARGER...
Crane Carrier Co. T/A New Way 31ASL 31Yd Side Loader Garbage Truck (A51692)
Crane Carrier Co...
