Tractor rocks going down the road
   / Tractor rocks going down the road #1
Fritzy
Member
I have a 3030 with a Cab which I use for snow blowing and cutting Grass. Most of my accounts are in town about 5 mile away and sometimes when the trailer is busy on other jobs I drive the tractor into town. The problem I have is the tractor at full speed rocks from side to side, not nice to drive. It's a little better if I drive on the gravel but it still rocks. does anyone know why it does this?
   / Tractor rocks going down the road #2
Flat spots in the tires from sitting
Maybe for the first few minutes but it's a good 20 min to get into town, I would think the tires would even out by then.
   / Tractor rocks going down the road #5
Does it do it at a rate that seems to coincide with the rotation of the front or rear wheels?
I have an idea...
   / Tractor rocks going down the road #7
My tractor didn't do it, but it does bounce after I got the tires full. I think at certain speeds the liquid kind of flops around in the tire causing it to bounce. Is that what is happening to you?
It doesn't seem to do it in any rythum, it will do it for awhile and then stop then start again.
The rims look good, I don't think they are bent.
I don't run it in 4wd on the road I don't know if that would make a differance.
I don't have any liquid in the tires.
   / Tractor rocks going down the road #10
One of the things to think about is that I have never seen a wheel weight on a tractor tire.
This probably means that the tires are not balanced, which is fine at low speeds, but may lead to problems at higher speeds.
I have no idea how to balance a tire if it is loaded, but you might ask at a truck stop if they can balance unloaded tractor tires.
2015 MACK PINNACLE (A53843)
2015 MACK PINNACLE...
2020 FAE QUICK ATTACH MUCLHING HEAD (A51247)
2020 FAE QUICK...
UNUSED X-STAR 101" X 25' BRIDGE PLATFORM (A51247)
UNUSED X-STAR 101"...
2017 FREIGHTLINER CORONADO SD122 DAY CAB (A53426)
2017 FREIGHTLINER...
UNUSED AGT AIR COMPRESSOR W/ 420CC MOTOR (A51248)
UNUSED AGT AIR...
2017 NISSAN NV200 VAN (A51406)
2017 NISSAN NV200...
