Mowing Efficient mowing pattern?
   / Efficient mowing pattern? #1
PM1
Member
Virginia
JD 5203 w/510 loader
By my quick-and-dirty calculations, I spent about 20% of my mowing time today turning corners and not cutting anything. In a rectangular field, I usually end up making 270-degree turns on each corner after the first few rounds. Each of those turns takes me around 12 seconds, which means I spend almost a whole minute each round not cutting, just turning. Today's mowing took 60 rounds, which means I spent about an hour of my time just turning corners without cutting anything.
Are there better ways to keep the cutter in the grass more of the time in a rectangular field? Thanks for any suggestions.
   / Efficient mowing pattern? #2
In my really big fields, I used Google Earth to locate the centers of a spiral cutting scheme. Start in the center and just keep turning larger and larger radii until you hit the fences. Then move to the next center. Fill in the uncut parts with conventional row cutting. I eventually changed the fencing to have round corners to make the mowing go better. Study the Zamboni trail on an ice rink if you still need a more conventional looking pattern. They do 1/2 of the rink and shift the cutting path up one row at a time until done.
   / Efficient mowing pattern? #3
The ideal field or lot would be a perfect circle..........maximum efficiency.
Since virtually all of them are not (unless you're in big irrigated farming country) you will have an angular piece of ground to cover and there is no way to keep mower or plow working 100% all of the time.
I turn the corners to keep them as square as possible meaning you leave an uncut/plowed bit at each of your corners that you then go back and cover once the main portion is done........"plowing out your corners" or mowing in this case.
In modern dryland conventional farming, as has been done for near a century now, no other method has evolved to truly replace the one I descibe above. It's how I was taught to operate and it's still the best way to cover an angular piece of ground that I have yet to find.
   / Efficient mowing pattern? #4
I think it depends on the discharge style of your mower. With my rotary mower and finish mower, both with rear discharge, I use the head row/wind row pattern alot.
   / Efficient mowing pattern? #5
I mow the headlands a few rows first. Then I mow up the long left side of the rectangle, at the end I make a sharp but comfortable u-turn to the right and return down the length maybe 6 - 10 rows over from the first pass. Then another right u-turn at the end and go back up along the right side of my first long pass. Over and over until that narrow section is done, and then start another one. I rarely having to slow down, shift, or stop.
   / Efficient mowing pattern? #6
I do mine like ford 850.
   / Efficient mowing pattern? #7
Break that large rectangle up into several small ones,than when you reach the end another end is always close,etc.
   / Efficient mowing pattern? #8
I guess I am the exception... I like to make my lawn decorative so with a home-made striping attachment, I am required to back up and turn around quite a bit... but the satisfaction of the results is fantastic. Otherwise, I do like 850 when I'm in a hurry.
Thanks for the replies. I see two schools of thought so far:
1) Mow in a spiral/circular pattern and clean up corners later, or
2) Mow in long strips, a few passes wide
It sounds like both of these would be more efficient than making square corner, 270-degree turns around a shrinking rectangle.
I think I can see how #2 is clearly better than what I've been doing. The field I mowed yesterday is roughly 600 feet x 600 feet, a little over 8 acres. I cut 5-foot swaths with each pass (6 foot cutter with 1 foot overlap). That means I have to make 60 rounds using the shrinking rectangle method. Each round has 4 corners, for a total of 240 turns. Each turn takes 12 seconds. That's a total of 48 minutes wasted.
If I mowed long, narrow strips, I might be able to make the U-turn at the end of each in the same 12 seconds it takes for the 270-degree turn I'm doing now. I would only need 120 strips, however, to mow a 600-foot wide field. That means only 120 turns instead of the 240 I made yesterday. That would mean 24 minutes less time turning - almost a half hour. That seems clearly better.
Am I thinking about this the right way?
I don't know how to compare the spiral/clean up corners approach. Is it even better?
   / Efficient mowing pattern? #10
With a square field the spiral method might be best. The spiral doesn't work well on rectangle fields say 600 x 1500 or so. Because you leave a lot at each end to have to go back and do. rectangles are best done by the method described above by taking smaller sections that go the length ways of the field.
Another option for a square field is what I do. When you get to the end, instead of making the 270 degree turn, just to keep the corners square, make the 90 degree turn.Yea you will miss a little on the turn, but just turn back into whatever you mowing ASAP. The next time around will get whatever you missed. This puts the cutter back to work faster. You kinda get the idea by the pic.
2018 CHEVROLET SILVERADO 2500HD (A55745)
2018 CHEVROLET...
2006 INTERNATIONAL 7600 T/A DUMP TRUCK (A51406)
2006 INTERNATIONAL...
2013 Cadillac ATS Sedan (A55758)
2013 Cadillac ATS...
2006 INTERNATIONAL 7400 6X4 DUMP TRUCK (A52706)
1995 Western Star 4900 T/A Wrecker Tow Truck (A53422)
1995 Western Star...
2018 UTILITY VS2RA 53FT REEFER TRAILER (A53426)
2018 UTILITY VS2RA...
