Trailer Brake Help Needed!
   / Trailer Brake Help Needed! #1
rah6965
Member
Carthage/Sanford North Carolina
New Holland TC48DA
I just bought an older deck-over trailer to haul my tractor and other heavy stuff. The trailer was made by Hudson in 1978, but it seems well built and actually heavier built than what I致e seen new at the dealers. I removed the old wood deck and figured now is the time to rewire the lights and brakes. It has brake hubs on the front axel only and I would like to add brakes to both, if it痴 not going to be too much trouble or expensive. The trailer has mobile home style axels and wheels, which I don稚 like but probably won稚 spend the money to convert all four to standard style wheels. My question is what do I need to get working brakes on both axels? The one with a brake hub may be repairable, but it looks like it痴 been disconnected for some time. The rear axel has a flange that the front axel doesn稚 have, but it doesn稚 look like a normal four-hole flange you see on most axels. Can brakes be installed on both axels and what would it take. I've attached some pictures that hopefully will help to see what I'm working with. Thanks in advance for any help.
:confused:
   / Trailer Brake Help Needed! #2
send a pm to diamondpilot, he most likely can offer some advice.
   / Trailer Brake Help Needed! #3
Thanks Radio Man. I stumbled on this one. Looks like a nice old trailer and man, that thing is built like a _________ brick house. Good find. As for the axles it looks like they welded the backing plates on the front axle and the rear axle still has some kind of odd ball flange. I would bite the bullet and put new axles with regular wheels and tires. But money can be a problem so If you want to use what is there I would first jack up the axle with the brakes on it. Apply 12 volts to the brakes, wires do not matter which is positive or negative, and see if they even work. If so, take apart, clean and inspect, then put them back together and use it with one brake axle. It will probably cost too much to convert the other axle to brake so when its time to upgrade tires, bearings/races, or something else bite the bullet at that time and change it over to modern axles.
Chris
Thanks for the reply. Do you have any suggestions for changing out the entire axel with new hubs. Is there a particular brand or type that I would need to use and how much would it cost. I assume I would need to get the axels locally due to the price for shipping such a heavy item. I guess I would also need to buy new tires and wheels for the new axels also. I only paid $800for this trailer, so don't know how much I should put into it. But, I guess since I haven't spent much yet I could make a nice trailer out of it.
   / Trailer Brake Help Needed! #5
Dexter is a good brand, the model would depend on how much weight the trailer rated for.
Aaron Z
   / Trailer Brake Help Needed! #6
Two 5200lb axles with e-z lube hubs, both with brakes will run @ 326.00ea.
3500lb axles 256.00ea.
The trailer is rated 12,000 lbs.according to the nameplate on the tongue and it is also on the title. I guess I would need to get two 6000 lb. axels. The trailer is built heavy enough to haul well over that. I guess I could put 7000 lb. axels under it, but the title and tag would still list 12000 lbs., so that wouldn't make much since.
   / Trailer Brake Help Needed! #8
Watch EBAY. I have seen 6K axles with brakes sell for as little as $145 each. Where are you located at? New axles are cheap around my parts due to the volume of trailers built here but I can put you in contact with some good companies. Shipping is not as bad as you may think. As for the $800 price, that is a steal. You get decent axles, new tires, a paint job, and a good deck and you have a trailer that would cost $4000 new. That give you plenty of room to put some money in it. What kills me is when I see a guy give $2500 or more then put $1000 in it and its still a old trailer. You did good on your purchase. And like I said before, you could just paint it, deck it, re wire it, and use it as is with the tires and axles you have but it will be a lot nicer and safer if you do it right.
Chris
I am located in central NC. They make Hudson, Kraftsman & Kaufman trailers all within 2 hrs. of my house. I guess I could check with one of those trailer manufacturers to see if they would sell me some complete axels, wheels, tires etc. at a decent price. If anyone knows of a good trailer parts supplier with good prices, let me know. Thanks for all the input.
   / Trailer Brake Help Needed! #10
Checking with them is your best option. As I said before shipping is not bad but if you could buy direct they should give you a good price. The manufactures buy them by the truck load.
Chris
2006 CEI  DRY BULK TRAILER (A58214)
2006 CEI DRY BULK...
COLEMAN GENERATOR (A52708)
COLEMAN GENERATOR...
DECORATIVE METAL GATE (A58214)
DECORATIVE METAL...
2015 CATERPILLAR D6N LGP HIGH TRACK CRAWLER DOZER (A52709)
2015 CATERPILLAR...
2008 Ford Fusion SE Sedan (A54815)
2008 Ford Fusion...
Yamaha Grizzly 125 2x4 Utility ATV (A59225)
Yamaha Grizzly 125...
