Permanent air lines
   / Permanent air lines #11
My shop at home and at work are plumbed with pvc.Both have been this way for over 10 yrs with no problems. What are the draw backs Kenny.
Bill
   / Permanent air lines #12
When PVC fails it fractures into semi-sharp fragments which are propelled throughout your shop by the compressed air. PVC is not rated for air pressure for this reason. They can be big pieces and propelled quite fast.
If you don't mind the chance of taking something that looks a lot like the spear that Oog the cave man used on miscellaneous game, right through your gut, there aren't many drawbacks.
The other problem is that the failure is not always rupture from internal pressure. If something hits the pressurized PVC pipe it can let go from that.
Water is OK because it isn't compressible and doesn't propel things the way air does. Although, I don't think I will ever forget getting whapped by a piece of 1-1/2" PVC which pulled out of a fitting and swung around on the end of a rubber hose. The only reason it didn't break my leg is that it hit my rear end instead. Left a huge bruise, which in time turned many amazing colors.
   / Permanent air lines #13
The ideal way to pipe is in a loop from compressor, around shop, and back to compressor in order to eliminate noticable pressure drop. In most cases for a small shop and a small compressor, this may not be a noticable advantage. Also, the extra pipe, especially in larger sizes like 2", increases system volume which is easier on a cycling compressor like a piston, as it will run slightly longer and stay off longer.
Cool. My system is a mix of 1/2 and 3/4" black pipe. Total run right now is around 50'. If i was to complete the loop it would add approx 40' to the run.
My compressor is 18CFM at 90PSI 60Gal tank and my system pressure is usually around 130-140. And i use ALL those 18CFM... I wish i had a bigger comp.
All my current run is sloped to reduce condensation. With drains and t's on each end.
I do a fair bit of painting and blasting. So my concern would be my desiccant dryer. Right now its on the end of my run, where the air is coolest and dryest. If i looped my system, the new section would be only 15' at the most from my blaster. I noticed my air was much dryer after i installed the long length of black pipe.
Attached is a quick illustration of my layout. Any ideas for improvement from a pro?
I also have a 30? gal old compressor that i was going to plumb into the system to use as an additional air tank. Is there any benefit to this? I know it will add to my compressor cycle times but when im blasting, my compressor hardly cycles anyways.. (yes i know this is bad:D)
   / Permanent air lines #14
I have 1/2" copper lines in my shop with 8 drops and no problems. I also have a drop in the outside pen where I keep the implements.
The compressor cuts out at 130-PSI, I have my circuits set at 100-PSI, and small regulators attached to all my blow guns.
   / Permanent air lines #15
Bill
Do a Google search "pcv for air". Dangerous stuff! In post #20 of THIS thread I put some links in to OSHA.
   / Permanent air lines #16
Why is it bad? Most industrial set ups run continuously. Stop start would be considered bad by many.:D
   / Permanent air lines #17
One way or the other, we all seem to get the air where it needs to be in order to get the job done.
Ah, yup, but with varying degrees of ease and convenience. You can share a fork between multiple eaters but it sure slows down progress.
My vertical compressor is in the garage so I can usually have a wall between me and the noise. There is an outlet there for tires and air tools if needed. The refrigerated air dryer is plumbed so it can be bypassed if desired. Compressor to filter and then dryer is PEX and then black iron on to the 4 outlets in the metal shop (a hair over 1000 sq ft) and 3 in the wood shop (a tad under 1000 sq ft). Several of the outlets are dual outlets with one being filtered dry air and the other with a filter-regulator-oiler for air tools. (You do have to keep the hoses separate. I have some wall mounted retractable spring loaded drums which are super convenient for getting a hose pretty much anywhere you want it fast and convenient. (I need some for electric too.)
The compressor is set for 175 psi and the regulator on the comp's outlet is set for 110 psi for distribution. The regulators out at the ends of the runs can be set for 90-100 for air tools. I would distribute at a higher pressure BUT... the dryer is not rated for 150 psi working pressure.
When I ran electricity to my relocated 35x70 barn I also buried a small plastic tube (ice maker tubing...yes it is rated for the pressure) to supply air to a recycled 30gal compressor tank (motor died after only 25 years or so) It is not a fast recovery situation but to start with you have 30 gal @ 110 psi, good for topping off a tire.
Pat
   / Permanent air lines #18
I've used PEX piping for my air supply in The GarageMajal. It works well, no failures, no leaks. Very flexible, takes a few minutes to plumb everything. Best part is if you need to expand, just cut, crimp in a "T", and go where you need it!
Mos heavy trucks don't use metal anymore. They use plastic. No corrosions and good anti-chafing properties. BUT, changing fittings sucks when it's -5f and the wind is blowing!
E
   / Permanent air lines #19
It may have been a mistake, but I used schedule 80 pvc for my airlines in my shop, but they are installed inside the wall, seldom used, and then at usually under 100 psi for nail guns. Seemed like a good idea at the time, 10 years ago. No problems, he said.
   / Permanent air lines #20
The key word in your post is INDUSTRIAL. Duty cycle on my compressor is 100% BUT:
My compressor never cycles because im using more air than i can generate (ie:bad). In use my line pressure will drop to around 40psi (bad) when i really want 90.
I really need a larger compressor for what i do.
Case IH 1063 Corn Head (A50514)
Case IH 1063 Corn...
LandPride RCF2072 (A50120)
LandPride RCF2072...
2012 Volkswagen Jetta Sedan (A50324)
2012 Volkswagen...
Tennant Floor Sweeper (A50322)
Tennant Floor...
Zimmerman 6 Lug Running Gear (A50774)
Zimmerman 6 Lug...
5-500 3 pt Spreader (A50515)
5-500 3 pt...
