i'm more worried about the girl with the boys head in the bucket. . .
What about the boy sitting beside her without the head?
Figured some astute observer would see it.
Evil the Weasel
Re: Installed Sunshade on BX2660 today
Is that the right sunshade for that model? Is that the regular or the deluxe one? It seems to me that a wood shim should not be necessary for the installation.
I don't know if it's right or wrong one or who would determine what the right or wrong sunshade for a BX tractor is. It's the one Barlows sold me for my tractor. I'm going to believe it's the right one because it seems to be the right size to me for my tractor. The wood shim is not necessary. I had it mounted without the wood shim and wanted a different angle so I added shims. I just wanted to change the angle and since it clamps to the roll bar the roll bar angle determines the angle of the sunshade. The sunshade I had on my L3240HST also had this same angle as it also clamped to the roll bar and followed the angle of the roll bar. I guess sunshades are made by different suppliers/brands and each one probably has their own mounting system. Don't know and don't care what brand this one is. It's solid, heavy, does it's intended job and to me seems to fit correctly.
DELInstallations
Looking at yours and comparing it to mine, it looks like mine is bigger. I know the mount to the ROPS is completely different on mine.
Don't you have a B instead of a BX? If so, they are different. The roll bar on B and BX are different. The mounting plates seem to be some type of universal mounting plates that can be installed in several different configurations. Probably to attach to even different brands of tractors. On my BX this seemed to be the only way they will fit. If I installed it on my B then I believe the plates would turn around and attach differently. Even then the top would follow the angle of the roll bar where it has to clamp to. As far as bigger, I guess again each company that makes them determines what size they will make them. My choice was a big one or a small one. For the BX I chose the small one. Actually traded a big one that was on my
L3240 to this small one for my BX. The one on my
L3240 had 2 handles that you pulled down to lift it off the tractor, then when you wanted to put it back on you just set the top back on and pushed the two handles back down to lock it back on. Could have kept the big one but I believe it would have been to big. I can/did drive into my garage with this one but it was close. Some dealers may have small, medium or large or even more different sizes. You probably have a different brand than mine. Don't think Kubota makes them, I think they are made by whoever wants to make them and then try to get a dealer to sell their product or maybe even market dirrectly to the end user.
