4WD Compact vs. 2WD Utility
   / 4WD Compact vs. 2WD Utility #21
One advantage of 4 wheel drive is you may be able to get along without chains for snow plowing if that is an intended use, especially if you have ag tires. Chains can be a clearence problem with fenders and front tie rod ends.
   / 4WD Compact vs. 2WD Utility #22
Tractors only had 2WD for years and years before 4WD. Farmers got by just fine then.
Eugene
   / 4WD Compact vs. 2WD Utility #23
Before tractors there were horses. Farmers got by just fine with them too. Have fun.
   / 4WD Compact vs. 2WD Utility #24
If you are looking for a tough, older tractor with 2wd, 3PH, around 45 HP, you would be hard pressed to beat a diesel Farmall 504. We have 2 that have been in the family since they were new. They are like the "Energizer Bunny" of tractors.
   / 4WD Compact vs. 2WD Utility #25
go with 4 wd! anything is better with 4 wd. amazing the difference !!!!!! try them out.
   / 4WD Compact vs. 2WD Utility #26
Hey Robert,
I'd sure hope so!!
Tim,
Do not leave out the David Brown tractors especially the later ones 885,990,Case 1190,1290,1194,1294.
2003 Chevrolet Silverado 3500 Crew Cab Pickup Truck with Gooseneck Hitch (A51692)
2003 Chevrolet...
2017 INTERNATIONAL PROSTAR (A53843)
2017 INTERNATIONAL...
BUSH HOG 2810CD SINGLE FLEX WING ROTARY MOWER (A51406)
BUSH HOG 2810CD...
2018 JLG 4045R 40FT. Electric Scissor Lift (A51691)
2018 JLG 4045R...
2012 GREAT DANE 53FT REEFER TRAILER (A53426)
2012 GREAT DANE...
UNUSED HURRICANE G350 MINI CONCRETE MIXER (A51248)
UNUSED HURRICANE...
