Any good tricks for treating posts?
   / Any good tricks for treating posts? #1
Iplayfarmer
Super Member
Idaho
Massey Ferguson 1215, Case 801B
I picked up a load of posts off Craigs List yesterday. It was a REALLY great deal until I realized that they are not treated. Now it's just a great deal.
I bought them to plant them for fence repair. What are some good ways to treat posts to preserve them when they are sunk in the ground?
   / Any good tricks for treating posts? #2
i have treated posts, even treated posts. I used a brush or small roller and applied a tar type paintable substance. guess you could use driveway sealer also. worked well.
   / Any good tricks for treating posts? #3
Stand them in a barrel of water that has some copper sulfate mixed in. They will soak up the solution.:D
   / Any good tricks for treating posts? #4
You could have a boot by PostSaver USA melted to it. With that you get (2) layers of protection from the earth (polyetheylene on the outside with a layer of bitumen on the inside between the plastic and the post. Check them out at Advanced-sol.com. What state are you in? They are in PA.
   / Any good tricks for treating posts? #5
Not sure what's the best, soak'em in diesel then let try and apply fence tar or driveway sealer???
   / Any good tricks for treating posts? #6
Go to (insert home improvement place of your choice, 'round here it's Lowes or 84 Lumber) and get some foundation sealer. Works great... Just get it on the posts and let it set a day or two or week..... it's messy but works.
   / Any good tricks for treating posts? #7
Lowes has a penatrating sealer,Jasco Copper Brown,suitable for treating wood in ground contact installations. The copper is the magic bullet for perserving wood. Jasco treat,let dry,and then seal with foundation sealer.
As an aside, archeaology digs have clearly established that wood in contact with copper and or bronze(which has lots of copper) will remain remarkably preserved for 100s of year. In contrast to recent history ,wood and iron combinations quickly rot and rust away.
   / Any good tricks for treating posts? #9
get a 5g bucket of asphalt fence paint or copper napthenat fence dip.. use that .. both great products.. watch out.. CN removes hair and leaves a near permanent green stain on just about anything including skin ( till it wears off anyway! )
soundguy
   / Any good tricks for treating posts? #10
The Amish around here drill an angled hole and pour used motor oil into post buried in the ground:I don't know how envirnomently sound this practice is tho.:confused:
JOHN DEERE HPX GATOR 4x4 *NOT RUNNING* (A50324)
JOHN DEERE HPX...
NEW Woods Reverse Rotation 5ft Tiller (A55218)
NEW Woods Reverse...
2021 NEW HOLLAND GS72 HD FRONT MOUNTED BRUSH CUTTER (A55218)
2021 NEW HOLLAND...
UNUSED HURRICANE STAND ON SKID STEER (A52706)
UNUSED HURRICANE...
12ft Heavy Duty Aluminum Ramps (A55301)
12ft Heavy Duty...
2018 PINSA 130BBL VACUUM TRAILER (A53843)
2018 PINSA 130BBL...
