Trailer Shocks Truck on Highway
   / Trailer Shocks Truck on Highway #1
wkpoor
Amanda, OH
John Deere 5400, Farmall H, Farmall Cub, Allis Chalmers CA
I really like the new trailer but have an issue that really raised its ugly head on my recent trip to Indy. On highways where expansion joints are under the pavement the trailer picks them up and sends nasty shocks waves at high frequency through the truck. So bad that after only a few miles it becomes un barrable. I assume the truck/trailer wheel base is close to 20' therefore just as one bump occurrs another comes right after therefore acting like a sign wave through the truck frame at a good rate. Enough to make your inerds feel like they are coming loose. Any thoughts on a remedy or what I'm doing wrong. Oh tried lowering tire pressure, doesn't really help but don't want that as a solution cuase when I get where I'm going and put a load on the trailer I'll have air back up. Its already been suggested slipper springs can do this.
OBTW....does the area around Indy have some of the worst roads in the midwest???
   / Trailer Shocks Truck on Highway #2
is your truck a dodge?
Hehehehehe no its Chev. However my guess is this problem wouldn't matter whats its attached to.
I went the same way back in May with a different trailer and didn't experience this problem at all.
   / Trailer Shocks Truck on Highway #4
our dodge exhibits that sort of problem whereas our chevy didnt. But the Dodge has a Cummins which makes it all worth it.
   / Trailer Shocks Truck on Highway #5
Where you loaded?:D....I mean the trailer...was it loaded?
   / Trailer Shocks Truck on Highway #8
I think what's happening is the road is driving a natural frequency of the vehicle and trailer as they oscillate around the hitch. It's a bit expensive, but I think a weight distributing hitch would solve the problem. You need to change the spring constant of the combined vehicle and trailer around the hitch, that should move the natural frequency away from the frequency that the road is driving. The weight distributing hitch significantly changes that spring constant, which is essentially zero right now. It has the added benefit of improving handling a bit and allowing a slightly higher tongue load.
Normally you could also change the mass of the system to get the same effect, but since you can only significantly change the mass of the trailer, and the trailer is mostly independent of the vehicle, that might not solve the problem.
   / Trailer Shocks Truck on Highway #9
did you try speeding up or slowing down 5 mph?
   / Trailer Shocks Truck on Highway #10
WKPOOR
I have experienced the same thing many times. I am guessing the stretch of highway you are talking about started 40 miles or so east of Indy on I-70. I can tell you I drive this road weekly, sometimes 3-4 times a week and its the trailer. I had the same thing happen with my buddies 14K dump behind my F-350. It seems to be worse with trailers that have the wheels aprox 60% of the way back from the tongue. Boat trailers, which I tow 90% of the time do not do it nearly as much. It think it has to do with the teeter/tooter effect. I towed a travel trailer down that road that weighed about 8K with my F-150 and it did the same thing. Made my innards feel like they were in a blender.
Chris
2021 Liebherr L556 (A53472)
2021 Liebherr L556...
2012 UNVERFERTH 13-INCH REAR SPACERS FOR 10 BOLT HUB (A53472)
2012 UNVERFERTH...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52577)
2018 FREIGHTLINER...
2024 KMC 7406 (A53084)
2018 John Deere 6215R MFWD Tractor (A53342)
2018 John Deere...
ASV Posi Tool Backhoe Quick Attach (A51573)
ASV Posi Tool...
