powerstroke444e
You found the exact wrong trailer and truck lenght. I had a ford with 18' trailer that would do the same thing on jointed pavement.
Chris you nailed it. East of Indy west bound side and around the south side of 465. Yep wheels 60% back.I have experienced the same thing many times. I am guessing the stretch of highway you are talking about started 40 miles or so east of Indy on I-70. I can tell you I drive this road weekly, sometimes 3-4 times a week and its the trailer. I had the same thing happen with my buddies 14K dump behind my F-350. It seems to be worse with trailers that have the wheels aprox 60% of the way back from the tongue. Boat trailers, which I tow 90% of the time do not do it nearly as much. It think it has to do with the teeter/tooter effect. I towed a travel trailer down that road that weighed about 8K with my F-150 and it did the same thing. Made my innards feel like they were in a blender.
I think what's happening is the road is driving a natural frequency of the vehicle and trailer as they oscillate around the hitch. It's a bit expensive, but I think a weight distributing hitch would solve the problem. You need to change the spring constant of the combined vehicle and trailer around the hitch, that should move the natural frequency away from the frequency that the road is driving. The weight distributing hitch significantly changes that spring constant, which is essentially zero right now. It has the added benefit of improving handling a bit and allowing a slightly higher tongue load.
Normally you could also change the mass of the system to get the same effect, but since you can only significantly change the mass of the trailer, and the trailer is mostly independent of the vehicle, that might not solve the problem.
As for the responses for the cushion hitches those are the wrong type for my problem. I have one like the first one and after a while the cushion takes a set and developes a dead space. Then you get clunking all the time. The second example is mostly for wagons and gravity beds that have no tongue weight but are heavy and will jerk to the truck for-aft. Only type that I can see helping are the ones like the Airlift that dampen the vertical ocsillations.
I really like the new trailer but have an issue that really raised its ugly head on my recent trip to Indy. On highways where expansion joints are under the pavement the trailer picks them up and sends nasty shocks waves at high frequency through the truck. So bad that after only a few miles it becomes un barrable. I assume the truck/trailer wheel base is close to 20' therefore just as one bump occurrs another comes right after therefore acting like a sign wave through the truck frame at a good rate. Enough to make your inerds feel like they are coming loose. Any thoughts on a remedy or what I'm doing wrong. Oh tried lowering tire pressure, doesn't really help but don't want that as a solution cuase when I get where I'm going and put a load on the trailer I'll have air back up. Its already been suggested slipper springs can do this.
OBTW....does the area around Indy have some of the worst roads in the midwest???
Now I live in northern CA where the interstates out here are in poor shape also (CA is near the bottom of the list in road quality).
What tears em up??? All that sunshine hehehhee.I think all entry points to California should have their signs changed. They should read:
"Welcome to California"
"Caution: Rough Roads"
