Pull Behind Sicklebar Mower
   / Pull Behind Sicklebar Mower
Thanks Dumbdog,
No doubt that experience is the best teacher. I'm grateful for the reply. I really need to find something to cut the creek bank. I could keep it looking great if I had the right mower. Thanks again. Kent
   / Pull Behind Sicklebar Mower #22
It looks like <A target="_blank" HREF=http://www.newholland.com/na/Products/Sicklebar.html>Newholland</A> is the only game in town. I see you already have a NH tractor, so maybe you have a dealer to call for price, or run an ad looking for a used one.
   / Pull Behind Sicklebar Mower #23
Steelfan - What I mean is that if you come to a tree or something you have to start turning way in advance. Plus, since the bar sticks way out it's hard to judge how close it is to something. For example, you might think you're going to miss a tree, but instead you're 3 inches off and will hit it, then you have to back up. Backing up a pull behind sickle mower would be tricky.
   / Pull Behind Sicklebar Mower #24
I don't know what they go for, but a local equipment dealer had about 8 of the 3pt, pto driven, gearbox type on his lot a month or so ago. I can't understand why the new ones go for so much since there shouldn't be much of a demand for them. Farmers used to use them exclusively before the haybine came on the scene about 25 years ago. They don't use them any more, so I would think there should be quite a few out there used. Now these were probably 7 or 9 footers - way too long for a compact tractor.
Seems to me that a guy with good torch and welding skills could take a 7' sickle and cut it down to whatever length he wanted. I had the pleasure of many hours of seat time on an 8N sickle mowing about 25 acres when I was a kid. It aint no fun! But with a modern compact and the right size sickle it should be OK. Besides, I just love the look of a sickle mown field.
Greg
   / Pull Behind Sicklebar Mower #25
According to Newholland, their model 451 7' sicklebar only requires 20 hp to operate.
   / Pull Behind Sicklebar Mower #26
I use an old John Deere #5 7 foot sickle mower on my 28 hp Kubota, I just got done mowing 80 acres of thick hay last week with it no problem at all just lots of time, I can go pretty fast, it doesn't bother the tractor at all, I have way more than enough power, just make sure you have new guards and sickle sections and a spare pitman around, it should work great. Chris
Thanks for the Reply Danny, and everyone else. I'm grateful for all the information. I'd hate to found out that it doesn't do what I want it to after I bought it. Thanks again. Kent
   / Pull Behind Sicklebar Mower #28
Kent, sounds like you've gotten some good advice here. Time to find a dealer & convince him to bring a unit to your ditch so you can try it out. Be sure to take some pictures, helps pass the day at work when I can't see big blue.
I saw an offset rotary cutter the other day. I think it was made by woods. It was mounted to a Utilitiy tractor. It was mounted to the three point & had a wheel just outboard of the tractor that it rode on. The cutter extended beyond the wheel. It looked to be able to pivot up & down. It did not have any ballast box that I saw, maybe the wheel kept the thing from tipping the tractor.
<font color=blue> sounds like you've gotten some good advice here. Time to find a dealer & convince him to bring a unit to your ditch so you can try it out. </font color=blue>
Great idea, Hazmat./w3tcompact/icons/clever.gif I wasn't able to get online for a few days. I may call the dealer Monday for a price. Thanks Kent
   / Pull Behind Sicklebar Mower #30
I read your post and remembered a customer that I deliver to. I stopped by his place the other day and he has a very very little tractor with a three point hitch mounted pto to belt drive sickle bar about 5 foot long. It had a HABINE RACINE
RACINE WISC sticker on it. Was white in color. You may do some searching in the Racine Wisconsin area if the manufacture is still in business. It was really cute.
   / Pull Behind Sicklebar Mower #31
Try this one !!!!
Haban Manufacturing, Inc.
2100 Northwestern Ave.
Racine, WI 53404
414-637-8388 Fax: 414-637-8389
   / Pull Behind Sicklebar Mower #32
Last week I saw a used 3pt, pto driven sickle mower advertised locally for $500. They're out there, and not too expensive either.
Greg
Thanks Again Everyone for the replies. I'm still looking. I found a New Holland 451 for $2500, but I was hoping to find one cheaper then that. I talked with a guy that I work with, and he said the NH 451 works great. It may take some time, but I'll find one for a decent price. Thanks again for all the help. Kent
   / Pull Behind Sicklebar Mower #34
Kent, ever since your original post about pto driven sicklebar mowers, I have been checking into them and discovered that with my 3 acre pond that's exactly what I need also. Now I will have to locate 2 (cheap) NH 451 7 footers before I can point one your way.
Normde2001, By the sounds of it , a sicklebar mower will do the trick for you also. Definitely let me know if you find 2 of them cheap. And I'll let you know if I find 2. Good Luck in your search. Kent
   / Pull Behind Sicklebar Mower #36
Look at the model RD160 made by VMC. This machine is a 60 inch flail, that operated either behind tractor or can swing outwards (hydraulic). The head will also tilt down or up to allow one to cut in ditches or trim branches.... Requires approx. 28 hp tractor and requires dual rear remotes. I have seen people use the loader controls to operate the machine.
The flail will cut much more than a sickle and much less maintenance. This is what I call a multi-purpose mowing machine.
ed.v
   / Pull Behind Sicklebar Mower #37
Ed:
Would it be possible for you to post some contact info for VMC. Thanks
   / Pull Behind Sicklebar Mower #39
Thanks Ed. I'm on pretty good terms with with Peiter so I'll give him a call.
Thanks Edv,
My tractor is a TC21D. I don't think the Flail is going to be an option for me. I just need a light duty side mower for weeds on my creek bank. I still think the Sicklebar Mower is my best choice. Thanks again for the reply. Kent
2019 Allmand Night-Lite V-Series 7 kW S/A Towable Light Tower (A55973)
2019 Allmand...
2016 Chevy Silverado Z71 4wd 5.3L V8 (A56438)
2016 Chevy...
1998 MACK DUMP TRUCK (A60430)
1998 MACK DUMP...
(INOP) 2016 CATERPILLAR 259D SKID STEER (A60429)
(INOP) 2016...
2016 Jeep Compass 4X4 SUV (A56859)
2016 Jeep Compass...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
