lakespirit
Probably unrelated, but I did the bypass from my alternator to put a charge into the battery (from the "need to rewire...KAMA TS254C" post) and now I can hear the sucker boiling inside the battery. There is battery fluid seeping out from the caps.
Probably unrelated, but just a few minutes ago the tractor started running kinda rough, and then just died. Thought maybe I'd run out of fuel, so I added five gallons, bled the injector pump and fuel filter just in case, and it cranks as long as I want to keep ignition switch on. It turned over and ran for about 15 seconds then died again. Not sure what this is about???
