This model appears to be a typ "contractors" style genset. Yamaha make qlty products. Do you have the need to justify the price for the amount of time it will likely be run? You have to decide.
As a contractor model it has to be running 3600 rpm while delivering any amount of power as it is needed to produce 60Hz A.C. One needs to have an inverter model for engine speed to vary with load. Down side to an inverter model is if you exceed rating for even a few secs, it will shut down the inverter. A non-inverter design will keep running and bog down some and returning to normal operation when load gets back down within range. This is an important factor when dealing with electrical motors as they need 2-3X the running current to get started.
The longer one needs to run a genset, the better the qlty of the generator one needs to withstand the rigors of long periods of operation at high loads. Some of the low end units are only designed to last in the hundred's of hrs and not thousands of hrs.
