8N doesn't start
   / 8N doesn't start #11
Autolites in my opinion did seem to work better. Champions are OK, but if I had my choice, I'd go with the Autolites. Sounds like I'm contradicting myself, but Farm & Fleet had a sale on them years ago, and of course I can't pass up a bargain, just had to get 10 sets. But you have to understand I had 7 tractors in my collection, that used that plug. When we would show them, I'd always have a couple extra sets in the toolbox.
Once the Champions were cleaned, they are OK... You may do as well with a small wire brush and some carb./brake cleaner. Even the Harbor Freight plug cleaners do a decent job. You can mount them on the wall, where it's handy to get to. It takes longer to remove and install the plugs, than it does to clean them. Just make sure the sand it all out of the plug when done.
Start with the easy items, such as cleaning, checking gaps, check for burned points, etc. If the spark in somewhat weak, it may be the condensor getting weak..., or just simple corrosion.
And something else that just came to mind.. You didin't say what year it was, or what type of cap is on the distributor. Square (Rectangular), or round. If it is round, is there a possiblity it may be off 180コ..?? Although it may cause it to fire on exhaust, but may be worth checking. It has been known to happen... You'll have good spark..., just not at the right time...
   / 8N doesn't start #12
CraigM,
You never did say if the plugs were even wet. Take the air intake off the carb and squirt some ether in the carb while cranking, and if it don't cough, fire or something. Even if the cap is 180 out, with ether in the chamber, it should fire, pop, etc. There is no reason that ether won't fire with a good spark.
   / 8N doesn't start #13
I prefer autolite 437.. though alc7 and the h10 or 12 work.. ( al 216 as well ).
don't forget to clean a plug that has been blasted with spray carb cleaner as it will have abrasive debri up near the insulator you can't see.. a surprising amount too!
soundguy
   / 8N doesn't start #14
IMHO.. that's BAD advice. A wire brush can leave metal particle tracks on the porcelan (sp?) insulator.. and lead to fouling.
abrasive cleaning works darn good.. if you clean the abrasives out afterwards..
soundguy
... You may do as well with a small wire brush and some carb./brake cleaner. ..
   / 8N doesn't start
My wife had to go to town today and offered to pick up plugs for me. I gave her the Autolite and Champion numbers listed in the posts. The autoparts store didn't have either, but crossed the Champ # to Autolite 4316. That scares me as I've always seen Autolite 437 spec'd for 8N. Should I hold out for 437, or figure that 4316 is 'close enough'...a phrase that always worries me. When I do finally get plugs that I'm comfortable with, what's the proper gap?
I don't know the distributor cap shape. Never looked that close. I was hoping not to have to get that into things as it looks ugly to actually get to the cap. Don't know the year either. It's not my tractor, my son and I are working on it for a friend with no time or indoor shop facilities. It ran last year, but sat for a long time and then was dead. He and I figured it'd be simple and good experience for my son. It has been....and then some.
We did finally get the plug wet with tons of cranking, but it wouldn't fire, even with the ether in it.
I really appreciate you guys talking me through this.
   / 8N doesn't start #16
"IMHO.. that's BAD advice. A wire brush can leave metal particle tracks on the porcelan (sp?) insulator.. and lead to fouling."
I won't disagree with that a bit. But if he doesn't have a plug cleaner, and not the right plug at the moment, and wants to get it running, I'd give it a try. That's all we did for years till we got our plug cleaners.
I suppose a good stiff toothbrush would work too if the carbon deposits aren't too hard.
If the cap hasn't been removed, it shouldn't be 180 out. Guess I was thinking i read where you had checked to cap.. Guess I misunderstood...
But I would take a peek under it, and check for buildup on the lugs. I got a buddy of mime's 9N running several years ago, and this was the problem.
   / 8N doesn't start #17
If it don't fire with ether, I don't think it is sparking. Are you using the 6 volt system or the 12 v system? Try taking all the plugs out and lay them on the block with the wires connected and crank the engine, and see if any or all the plugs are firing.
   / 8N doesn't start #18
I think it is great that you and your son are working together to help your neighbor out. I know it is hard when you don't know the machine. Here's what I suggest.
If you want to help your son have a good experience in his first repair job, start him off right by getting the manual, read through the pages about the ignition system and tune up procedures. The owner can get a manual from stores like TSC, maybe from New Holland as well. For all the time you are putting into it, a few $$ for a manual is probably worth it. My recollection is that they cost about $15-20. The old Ford manuals are very easy to follow, with lots of black and white pictures.
Also, are you sure it is an 8N, or could it be a 2N or 9N. Lot's of people call them all 8N's. While all three are similar, there are differences related to the distributor and perhaps some other parts of the ignition system. The manual for the Ford 8N, 9N, and 2N will help you discover which you have by looking at serial numbers and matching pictures to what you have.
The other differences you run into is that these were built as 6 volt machines and some people have changed them to 12 volt. You need to determine which you have if you are going to replace certain components. Mine was 6 volt, so I'm not sure which components are different in 12 volt.
It certainly is a good idea to replace the plugs they are cheap so go ahead and replace them whether it is the root cause or not. The manual will tell you what plugs and the gap necessary. Then if it doesn't start, you really need to check the other components which means you'll have to check the distributor. With a manual you should be able to do that.
It has probably been a long time since it has been properly tuned, so you might as well replace points and condensor as well. How are the plug wires? Are they frayed or cracked? If you replace them, make note of which wires go where on the distributor and cylinders. You might need a new distributor cap.
I think a thorough tune up will reward the owner and make you and your son feel great about the experience.
   / 8N doesn't start #19
a 4316 crosses over to an H10C.. so yes.. it will screw intot he hole and make sparks.. it would NOT be my first choice. A champion H12 ( 512 ) would be a better option.. a motorcraft al7c is also a good fit and is the current oem plug specified by CNH.. etc.
soundguy
   / 8N doesn't start #20
Also, are you sure it is an 8N, or could it be a 2N or 9N. Lot's of people call them all 8N's. While all three are similar, there are differences related to the distributor and perhaps some other parts of the ignition system. ..
You are making this too hard. Ford N series used 2 distribuitors stock.. a side mount.. and a front mount. front mount was the same for the 9n, 2n, and early 8n.
parts for the frontmount fit all the front mounts. parts for the side mount actually fit all the 4 cyl gassers up to 64.
The manual for the Ford 8N, 9N, and 2N will help you discover which you have by looking at serial numbers and matching pictures to what you have..
Not even that hard... 3spd tranny = 9n/2n 4spd tranny = 8n
big rear axle nut = 8n.. smooth or rivited rear axle hub = 9n/2n
still.. the engine will have a sn on the side, above the starter, below the head that will tell you what the engine went to. All N engines swap.. so then you date the codes on the chassie to see if your engine matches your chassie.. general thoughts are if the casting codes and engine number all meet up within about 3 months or so.. you got a machine with no major swapped components.
soundguy
2015 Nissan Altima Sedan (A59231)
2015 Nissan Altima...
1408 (A57192)
1408 (A57192)
2012 KOBELCO SK170-9 ACERA MARK 9 EXCAVATOR (A60429)
2012 KOBELCO...
2014 Freightliner Bucket Truck (A56438)
2014 Freightliner...
2018 MACK GU813 DUMP TRUCK (A59823)
2018 MACK GU813...
2012 Dodge Avenger Sedan (A59231)
2012 Dodge Avenger...
