GREASE... every 10 HOURS?
   / GREASE... every 10 HOURS? #21
But there are scores of members that will wear out pins & bushings prematurely due to a lack of maintainence.
Well, I can't argue with that...
I really appreciate everyones input!! I think I will continue with the every ten hour thing! Just have to buy more paper towels. As soon as the weather warms up a little more I plan on giving her the first pressure wash she ever had. This hopefully will get rid of excess grease and I will be able to start all over again.;)
   / GREASE... every 10 HOURS? #23
I grease mine using the guesstimate method. I can pretty much figure out when the front loader or backhoe gets used for approx 10 hours...then they both get greased. When I pressure wash it though, they both get greased regardless of hours.
Deano
   / GREASE... every 10 HOURS? #24
I've never been able to get all the grease with just the pressure washer. But maybe that's cause I'm too scared of taking off the paint:D. I too say grease grease grease:D.
   / GREASE... every 10 HOURS? #25
I remember when we had our land cleared for the house, the local sand/gravel/heavy equipment/paving company sent a crew out for about two weeks.
They all greased every piece of equipment at the end of every day. Each operator did his own machine. Essentially if the machine went down, the operator was out of work until it was fixed. Big motivator to keep it maintained.
   / GREASE... every 10 HOURS? #26
One little detail that deserves mentioning is this: an hour meter (at least on my B8200) is reading hours based on 2600 RPM engine speed. i.e., run the tractor for 10 hours at an average of 1300 RPM, and you'll see 5 hours on the meter. At least, that's what it seems to me. Am I wrong about this? I keep meaning to actually test it, but always forget.
   / GREASE... every 10 HOURS? #27
I think you need to check that. I believe the hour meter starts running when the electric hits it and stops when the electric stops. I'm not betting money on it but I believe that's how it works. I bought a mower one time that had a few hours on it but it had never been used. I think they forgot and left it running when they were servicing it and maybe took a break.
   / GREASE... every 10 HOURS? #28
Ten hours of loader work is a lot. I grease my loader about twice during the summer months. I use it that little during the summer. This past week I used the loader about 40 hours pushing snow. I greased it twice. I use New Holland Ambra on everything that has a grease fitting. Tractor, attachments, and everything else.
What "one tube does all" grease available at TSC or Wal Mart do some of you greasers use?
   / GREASE... every 10 HOURS? #29
I believe you are correct about the hr meters.
I use the cheap stuff from TSC buy it when it is on sale by the box{something like 1.00 per full size tube}. I have a lot of greaseable joints{multible machines}. I've been using it for a few years now with no issues.
   / GREASE... every 10 HOURS? #30
I been testing out the green synthenic stuff from TSC on the all of my bushings, bearings since I had the bota. Only time I don't use green grease is on the HST pedal pivot zerk. I use the lighter light duty tan stuff on that. I notice the tan stuff works better to clean out the bushing and prevent stickness. The green stuff just stays there and makes tredle stick and slower response.
2013 Dorsey Pitts 48ft. 40 Ton T/A Flatbed Equipment Trailer (A60460)
2013 Dorsey Pitts...
25 TANDEM DUAL GOOSENECK TRAILER (A55745)
25 TANDEM DUAL...
2005 Peterbilt 357 Truck (A55973)
2005 Peterbilt 357...
2007 JLG E400 AJP TELESCOPIC/SCISSORING MANLIFT (A52707)
2007 JLG E400 AJP...
2018 CATERPILLAR 242D SKID STEER (A60429)
2018 CATERPILLAR...
2022 Ford Explorer AWD SUV (A59231)
2022 Ford Explorer...
