Back Yard Mechanic needs to Drill 7/8" Hole
   / Back Yard Mechanic needs to Drill 7/8" Hole #11
Cheaper, yes. $36.99 plus shipping
I have been using a set of these for a couple of years. They are holding up just fine but I don't drill big holes very often.
8 Piece Silver and Deming Drill Bit Set
Top quality M2 high speed steel bits
Black industrial finish
Precision ground
Includes handsome fitted wooden storage case. Shank: 1/2"; Sizes: 9/16", 5/8", 11/16", 3/4", 13/16", 7/8", 15/16", 1"
$36.99
Like Oasis, I've had good luck with my set of S & D twist drills. Sounds like the same set except my wooden case is anything but handsome! Anyway, 700RPM is about 50% too fast for drilling 7/8" in mild steel. Once they overheat, they'll lose there hardness so don't push them too hard for too long.
Thanks for all the feed back. I never thought of a hole saw.
I was mostly concerned about the 700 rpm on my drill press.
It seems a little fast to me for a 1/2" hole so I was worried
about a 7/8" but I sounds like I should be OK.
If the hole isn't perfect nobody will notice - I cut all the steel
plate with a Sawzall. I clamped a couple of angles back to back
on either side of the cut line to use as a blade guide. Actually it came out
pretty good. Think I'll look for some cheap drill sets.
Thanks alot.
   / Back Yard Mechanic needs to Drill 7/8" Hole #14
What are the advantages of using windshield washer fluid as a lubricant? I've heard of using ATF, but this is the first time I remember anyone suggesting washer fluid.
I've not had good luck with large, cheapo drill bits. Seems like I ruin them pretty quickly.
   / Back Yard Mechanic needs to Drill 7/8" Hole #15
Whenever we've had to cut holes in machine tabletops, we've used the Lenox hole saws too. Portable, way less tailings and easy to spot. The windshield wash takes the heat away and keeps the metal from sticking (melting) to the saw teeth. I've used water with a little dish detergent in a tank sprayer with great results too. We've cut through 1 1/4" steel plate with a hand drill in about 10 minutes. It's great for big bolts and hose passages.
   / Back Yard Mechanic needs to Drill 7/8" Hole #16
Carbide tip hole saw and some cutting oil.
I use the cutting wax... I've drilled hundreds of 7/8" with the same carbide tip hole saw with cutting wax in heavy duty commercial grade panels...
Don't take it the wrong way, cutting oil will work too.
   / Back Yard Mechanic needs to Drill 7/8" Hole #17
My drill press has a double reduction belt drive so I am sure I can get down to around 250rpm. I believe I only paid about $100 for it at Menards. It is a floor standing unit.
The slowest part of hole drilling is punching the first hole through. A 1/4" high quality drill is the best (you can afford to buy several in such a small size). Key with drilling is to never let the drill rub. From the get go you need lots of pressure (proportional to the drill size) to keep the cutting edge cutting. A continuous string of swarf should emerge and ideally flood it with coolant to keep the temperature down.
3/8" is not very thick material, unless you overheat the drill and dull the edge. A technician who fitted a tow hitch to my Cobalt spent 15 minutes trying to drill a single hole through a high strength reinforcement on the floorpan (it was just over 1/16th thick). It was alloy steel that was harder than he expected and his drill bit was blunt. He put a jack under the drill to get more force but all he got was the tip of the drill glowing red hot. I walked across the street to a hardware store and bought a new drill and he put it in and it went through like butter.
A job I had years ago required special hard drawn chrome copper bar to be drilled through from end to end with an 11mm hole. There were about 500 of these parts, ranging in length from 2ft to over 6ft. The special copper itself was air freighted from Australia, the only place in the world it was available within the need lead time. I then had all that copper bar cut to length and sent to a small arms manufacturer more than 600 miles away, who had a high power gun drill that could process all the bars in a short time. All the material had to make the trip there and back across africa without being stolen (the value was a significant fraction of the then gold price). Those holes were so perfect that any one of them would have make a good smooth bore rifle. We paid them to run their machine, plus they kept the drilled out core as valuable scrap, I'm sure it was a good deal for them... Some time later I needed a piece of material to make a special 3" diameter washer and had the storeman slice me off a piece a bit more than 1/4" thick (was the finished size) and after he weighed it he said the material alone for the washer was worth more than $5 (that was in 95 !) I'm sure if I had screwed up that job, they would have tied couple of "useless" bars around my ankles and sunk me in the bay...
   / Back Yard Mechanic needs to Drill 7/8" Hole #18
Recently I needed a fairly close tolerance 3/4" hole.
While hole saws cut well when lubed, they end up in a loose fit. SO, I ground off the outside staggered teeth to be flush with the drum (bell).
Was surprised to find
A -cutting was excellent, in fact better than with staggered teeth.
B -no binding and cleaner cut
C -teeth no duller, perhaps even better.
Staggerd teeth are much better for wood in that wood binds due to sawdust while metal does not swell like wood.
I lubed with what I had on hand; WD40.
I have even bored 3" holes in 1/2" plate with a quality hole saw on my press drill. Worked fine!
   / Back Yard Mechanic needs to Drill 7/8" Hole #19
if one has a cutting torch one can cut a rough hole and then weld in a bushing or a shaft collar,
   / Back Yard Mechanic needs to Drill 7/8" Hole #20
I always thought those hole saws were strictly for wood, just by looking at the teeth on them. I never dreamed that you could drill holes in thick steel until i read this. I can't wait to try it out.
Flat Deck Trailer (A50322)
Flat Deck Trailer...
2015 JEEP PATRIOT (A51406)
2015 JEEP PATRIOT...
Morooka MST 660VD Tracked Dump Truck (A51039)
Morooka MST 660VD...
2006 CATERPILLAR 330DL EXCAVATOR (A51242)
2006 CATERPILLAR...
CASE 850M WT CRAWLER DOZER (A51242)
CASE 850M WT...
2014 MultiQuip WhisperWatt 40kW Three-Phase Diesel Generator (A49461)
2014 MultiQuip...
