Check out this BX Grill Guard
   / Check out this BX Grill Guard #1
montelatici
Croom, Maryland
Kubota B2601 and L3560 HSTC LE
Bought this grill guard for BXs from Fabworks O.E.M.
Fab Works OEM
Clever idea adds a trailer hitch and a hook which should make it quite useful if you need to move a trailer or pull something with the hook, albeit pulling in reverse.
   / Check out this BX Grill Guard #2
Does give BX meaner look. :)
   / Check out this BX Grill Guard #3
I saw them selling these on eBay, too. Great solution if you need both the grill guard and hitch, and it's priced right. What do you think of the build quality?
Real solid and heavy construction. Welds don't have that high production rate robot look, but they look strong. At $139 it isn't a bad deal.
is that polished aluminum? or just aluminum looking paint?
No it is steel and painted. I don't think aluminum would have the needed strength for the trailer hitch/draw hook function.
   / Check out this BX Grill Guard #7
A front hitch is very convenient for backing trailers into tight places. However, I'd be VERY careful about how much tongue weight you put on it. That front axle is stout, but....
Do you think a trailer that you can pull with a car would have more tongue weight than the FEL and a full bucket?
   / Check out this BX Grill Guard #10
very cool, do they make them for little green one as well? and do you have a link. Thanks
NEW Slip On Fork Extensions (A53002)
NEW Slip On Fork...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52576)
2019 FREIGHTLINER...
3 POINT  7FT RAKE (A52472)
3 POINT 7FT RAKE...
2004 PETERBILT 385 (A52472)
2004 PETERBILT 385...
2016 E-Z Beever M12R Towable Brush Chipper (A51691)
2016 E-Z Beever...
