JOHNTHOMAS
Super Member
- Joined
- Apr 14, 2008
- Messages
- 7,719
- Location
- Somerset, Ky
- Tractor
- F2690 4WD RTV X1140 MX5400 HST ZD1211
You need to always buy from a local dealer and never consider the internet dealers.
You need to always buy from a local dealer and never consider the internet dealers.![]()
I'm not surprised your gauge is still reading full. If you are not running close to wide open, the little BX1860 is outstanding on fuel usage. I have just under 100 hours on mine and I've used 5 or 6 five gallon tank fulls in that time yielding between 3 and 4 hours per gallon. Most of the time I run at 2,000 to 2,500 rpm for tooling around or light loader work. If you do a lot of mowing at WOT, expect half that efficiency.
My guage will stay at full for many hours before dropping, then it will drop more uniformly. I think it has something to do with the shape of the tank. I don't think it's terribly accurate between full and 1/4 tank give or take. It will show less than full when on a slope, then come back up once on level ground; again due to oddly shaped tank I assume.
My guess is your fuel gauge is not broken but suffers from the usual flakiness. That and your lack of exposure to how efficient these little diesel beast are.![]()
OK enough with the GAS or you better not be using gas.I never went beyond 2300 rpm and you said 3 to 4 hr per gallon, I saw people said 1/2 gallon per hr, well not sure but surely it does look flaky and I am the kind of guy when you put 13k on it, I expect it to work atleast gas gauage and gas guages have been around for what 70 years now and it requires little or no reasearch anymore. Worst thing for the farm tractor to be stuck without gas far in the field. I will see how this guy fixes it up. My neighbour has BX1500 and his gas guage is fairly accurate.
