ALWAYS use 4wd on hills!
   / ALWAYS use 4wd on hills! #11
To think, I've been dodging death every day for years using a 2wd tractor on steep hills. :rolleyes: As rjkobbeman mentioned, it has more to do with going straight down hill when possible, and going slow when conditions call for it. Common sense must be used no matter what technology you have.
:thumbsup:
   / ALWAYS use 4wd on hills! #12
If you make your money working a tractor...yep, then you may have to work it in wet conditions. Hopefully, you'll know the risks and what you're doing.
If you're just a hobby guy (like I am), there's no good reason to risk going downslope in wet conditions with or without 4WD.
So, it's slick out..and do you really need to do that chore or task today? That's the question you need to ask yourself.
The other part of the equation is gear selection. Going downslope, go in as low a gear as circumstances demand.
   / ALWAYS use 4wd on hills! #13
Unless its a gas engine, I didn't think diesels gave any engine braking? It seems with it in gear, it will slow it down some on its own, but is this due to engine braking?
Yes, it's engine braking - diesels typically have a higher compression ratio than gasoline engines, so all other things being equal you'll actually get more engine braking from a diesel...
   / ALWAYS use 4wd on hills! #14
I seldom have to use the brakes on my 4300HST while going down hills in 4wd, just lift my foot and tractor slows, as long as I'm in low range. Gotta be engine braking.....
When I do use the brakes I find its impossible to get even braking on both sides, no matter how carefully I've adjusted those brake rods......even so, there are times when a bit of braking gives a lower pucker factor...
   / ALWAYS use 4wd on hills! #15
...so all other things being equal you'll actually get more engine braking from a diesel...
Sorry, but that's not right. Most engine breaking in a gasoline engine comes form the engine trying to pull air through a closed throttle plate. Since a diesel engine does not use a throttle plate, it has very little engine breaking compared to a similar gasoline engine.
   / ALWAYS use 4wd on hills! #16
He he he.. I guess all my tractors have throttles that create a vacuum then, cause when I'm heading down a grade and I back off the engine rpms, I get pretty good engine braking. Maybe someone forgot to tell them they're diesels? ;)
   / ALWAYS use 4wd on hills! #17
Rob,
are you stating that creating a vacuum will give more braking than compression will?
Roy
   / ALWAYS use 4wd on hills! #18
Rob,
Roy
Here we go, any guess's on how long this thread will go now???? :)
   / ALWAYS use 4wd on hills! #19
Rob,
Roy
You got to be a little careful here, 'cause there is more than one force at work. Rob is right that a vacuum due closed throttle is a powerful thing - for instance, when you do a compression check on a gas engine what position does the throttle have to be in? But there are still powerful engine braking forces in a diesel engine, otherwise if one is going down a just a slight grade with a load on, why is it that backing off the throttle will usually provide enough braking? What is it that stops a diesel in this (non-severe) case from over-reving, potentially to destruction? Most anyone who has gone done a snow covered slope in a 2WD tractor and had the rear end start to slide has had the experience of having to push in the clutch to disconnect the engine from the drive train to get the wheels turning again... that's due to good engine braking...
   / ALWAYS use 4wd on hills! #20
No guesses from me, the only hint I can offer is that I was typing while you wrote this... :D
2001 International 4700 Dump Truck with Compressor, VIN # 1HTSCAAN91H363922 (A51572)
2001 International...
2008 KENWORTH T-300 LUBE TRUCK (A52472)
2008 KENWORTH...
2007 Eager Beaver 35 GLB Lowboy, Tandem Axel (A52384)
2007 Eager Beaver...
2008 KENWORTH T800 TRI-AXLE (A52472)
2008 KENWORTH T800...
Skid Steer Sweeper Attachment (A51573)
Skid Steer Sweeper...
2025 25ft. 800Amp Extra HD Booster Cables (A51692)
2025 25ft. 800Amp...
