"Pull" bush hog, or lift it when travelling?
   / "Pull" bush hog, or lift it when travelling? #1
beppington
Elite Member
of my
Here
Would you all suggest I lift my rotary cutter/ bush hog fully with the 3PH when travelling the 4-mile route from my tractor's home to my new property I'm working on ... or raise it a little and let the cutter's single wheel carry it?
There's a pretty noitceable difference in hydro whine when travelling with the cutter lifted off the ground; Doesn't seem like a big problem, just curious.
2 miles of the trip is pavement. The other 2 is packed/ graded limerock.
The cutter's tire is one of those solid-ish rubber tires like this (called laminated, I think):
   / "Pull" bush hog, or lift it when travelling? #2
I seem to remember a thread about traveling across a field with a hog on the 3point and hitting a big bump. Broke major parts inside. I would rather wear down and replace a $40 wheel than something big. If your gravel roads are in need of grading you will surely find some potholes.
   / "Pull" bush hog, or lift it when travelling? #3
I always lift completely for any extended period of travel.
I can't imagine the weight of a 5'/6' shredder for that amount of time to be a problem for your tractor......that's pretty much what it's designed to do.
   / "Pull" bush hog, or lift it when travelling? #4
If your cutter wheel bearing setup is like the lower one in the pictures, I would not run it on the ground no more than necessary. Those are just bushings and will wear out soon enough? Roller bearing setup lots better. Ken Sweet
I'll have to check & see what it's got for bearings; It's actually my dad's ... the beast in question (why I didn't think to post this pic instead of the one above, I do not know :laughing:):
   / "Pull" bush hog, or lift it when travelling? #6
Is that snow or beach sand in that picture? Nice looking outfit. Ken Sweet
Huh, I didn't even notice that - It can only be ... limerock dust! From the 2-mile limerock road stretch back from my property.
Tks for the compliment!
I no longer use that chain around the wheel, by the way. Now that I know how easy it is to simply shorten the upper link to raise the cutter's rear way up. Learnin' ...
   / "Pull" bush hog, or lift it when travelling? #8
I always raise my cutters when transporting and one is a ten foot Woods 121, never had any problems breaking things and the wheel hitting a pot hole can affect handling or damage stuff too. I have a pull behind, but it has airplane tires so they wear well.
   / "Pull" bush hog, or lift it when travelling? #9
They are made to be lifted.
   / "Pull" bush hog, or lift it when travelling? #10
Looks like a pretty beefy cutter to me. I don't think I would want all that weight bouncing around on the 3pt system for 4 miles. Me I would let the tail wheel carry some of the weight.
MarkV
2009 MACK GRANITE (A52472)
2009 MACK GRANITE...
2010 FORD F750 XL SUPER DUTY DUMP TRUCK (A51406)
2010 FORD F750 XL...
2019 Allmand Bros Maxi-Lite II Towable Light Tower (A52377)
2019 Allmand Bros...
2006 TerraGator 8104 (A55301)
2006 TerraGator...
BUYERS PREMIUM & PAYMENT TERMS (A54313)
BUYERS PREMIUM &...
KUBOTA RTV X1100C UTV (A51406)
KUBOTA RTV X1100C...
