Chainsaw Post Pointer
   / Chainsaw Post Pointer #1
niemeyjt
Suffolk UK / Lausanne CH
Kubota B1750
I needed to repoint a few posts and found the chainsaw did a surprisingly good job, if slightly uneven.
This set me thinking - has anyone made a framework / jig for this type of operation?
J
   / Chainsaw Post Pointer #2
J
I understand every word, but your meaning escapes me :confused:
What is it to point a post?
   / Chainsaw Post Pointer #3
He's looking a for a jig/attachment he can hook to the chain saw to re-point posts. Not sure if one exists for a chain saw, but I would use a cordless saws-all. If you're wanting symmetry a tape measure and pencil would work.
Wedge
   / Chainsaw Post Pointer #4
are you talking about just slashing the top off at an angle so that the tops shed water....
or actually talking about the look you get from putting the post in a gigantic pencil sharpener... were there is a bevel all the way around with a point in the middle.
   / Chainsaw Post Pointer #5
There is a beam make attachment for chainsaws for making straight lines. use a 2 by 4 for guide. Its about 40 bucks the last i knew.
   / Chainsaw Post Pointer #6
(I still have all this in the corners of the sheds....)
Dad had a circle saw - buzz saw - on the H tractor, for cutting forewood. I think most of you here would cringe at the danger of those things. I spent 3-4 days every fall as a kid taking the cut wood away & throwing in trailers & trucks. Life is good when you pay attention or die. You learn to pay attention. ;)
He made an oak plank for it, that would bolt on the side in place of the cradle. He could slide the raw wood posts on the plank, and cut points on one end so they would pound into the ground with a sledge. The other side he even trimmed little miters off, so the post wouldn't split from the maul pounding.
He could shape up 50-60 posts in a short afternoon, looked like factory made posts, most from reused telephone poles or home cut white oak branches.
There was no kickback device, no guides, no guards, no nothing. This was just a flat table on a 3-4 foot rotating blade on the front of a tractor powered by a flat belt & pulley. Pretty much a tractor-powered 4 foot table saw with nothing but the blade.
Life was different back then. You would all be very, very scared seeing this setup..... That one actually got my notice as to what happens if.....
So anyhow, yea I know what you are talking about. Don't have any help for a chainsaw jig tho.
--->Paul
   / Chainsaw Post Pointer #7
HF carries a cheap one and Bailey's more expensive (and probably better) version. I have the HF one and it works well enough.
   / Chainsaw Post Pointer #8
--->Paul
Paul,
My Dad had a similar setup for cutting up slabs for use in our wood-burning stove. His rig was stationary and we hauled in the slabs from a sawmill. The rig was powered by an AC WD 45. Thinking about it gives me chills. It's a wonder that he never had an accident.
Steve
   / Chainsaw Post Pointer #9
Paul,
Steve
Amish have them at every farm just about AROUND HERE. It is still common and about 10~15 yrs back a 16yr old was caught up in one & he was gone in a flash. took him in two parts across from shoulder to waist on one side to other side. His dad said his coat snagged the blade & pulled him in.
Mark
   / Chainsaw Post Pointer #10
I have seen one made out of a dish shaped disker blade. The disk was sharpened by hand and mounted to an electric motor on a swing arm. The post was set on a fixture that contained it while letting the operator turn it with their left arm.
The post did not get a perfectly round point like a pencil. It had roughly four cuts to form a crude point. The operator would place a post in the fixture. Pull the saw towards them while cutting the end/side off of the post. Releasing the saw which would retract back via a spring, the operator would turn the post 45 degrees and make another cut.
A few more cuts and walla', you have a somewhat pointed post to pound into the ground.
UNUSED EINGP F10 - 10' WROUGHT IRON SITE FENCE (A54757)
UNUSED EINGP F10 -...
2022 ONYX RX34 FLOOR SWEEPER (A50458)
2022 ONYX RX34...
2018 KENWORTH T270 SERVICE TRUCK (A51406)
2018 KENWORTH T270...
Miller and Smith PNR-1000 Pull-Behind Proof Roller Trailer (A52377)
Miller and Smith...
UNUSED LANDHONOR MAP-16-24W MINI MOUNT PLATE (A54757)
UNUSED LANDHONOR...
