New Implement Shed
   / New Implement Shed #1
Storm56
N/A
N/A
A few pics of the implement shed that a few friends and I built over the last 2 weeks. This all started when I purchased the new McCormick this year and did not have enough space in the garage. I also had several items that I was storing under tarps which my wife just hated. So what else to do but put up another building!
   / New Implement Shed #2
Looks good! 16x32?
Thanks! 20x40
   / New Implement Shed #4
Looks good, what did you coat the bottom of the posts with?
Russ
   / New Implement Shed #5
Good looking shed. I built a 20x28 ft version a few years ago for my haying equipment.
Russ
I wrapped them with 90# felt paper and used ice & snow shield on bottom of the poles. I figure they will be around longer than me!
Thanks for the compliment!
Ice & snow shield is a tarpaper like product that has a sticky side and is designed to adhere to the plywood on a roof and stick fast. The sticky part seals around the nails that would be used to put shingles on. It is used on the bottom 3 feet or so of the roofs in northern climates that are subject to ice dam buildup.
I just had some left over from the house that I built 3 years ago and felt that it would be a good product to use on the bottom of the pole. Just trying to do what I could within reason to make the poles last as long as possible. It is much easier to take a few minutes and prep the pole before it goes in the ground than digging them up later!
   / New Implement Shed #10
Id love that but would want doors on front. Now if I knew how Id be in business
2014 Toro Workman HD 07369 Utility Cart (A54811)
2014 Toro Workman...
(NEW) 2025 DOWN 2 EARTH GOOSENECK TRAILER (A51247)
(NEW) 2025 DOWN 2...
KUBOTA RTV X1100C UTV (A51406)
KUBOTA RTV X1100C...
1988 Kenworth W900B Dump Truck with 3406B CAT (A55218)
1988 Kenworth...
2006 Utility Trailer Trailer, VIN # 1UYVS13256P972701 (A53422)
2006 Utility...
UNUSED CFG INDUSTRIAL H15R EXCAVATOR (A52706)
UNUSED CFG...
