Front axle pressurized?
   / Front axle pressurized? #1
mjonesnh
Tennessee
TC34DA
Checked the fluid level a couple days ago on my TC34DA and when I unscrewed the dipstick there was a definite sound of pressure being released. This is the first time I can remember this sound when the dipstick has been removed. The fluid level was up to the full mark but not beyond it, tractor parked in shed so not in direct sunlight. Tractor had not been used for over a week so I am at a loss for an explanation. Anyone else ever notice this on their 4WD New Hollands?
   / Front axle pressurized? #2
Yes, I've noticed it on my TC45D when I check the front axle level after using the tractor for awhile, especially when it is hot out. I think it's normal.
   / Front axle pressurized? #3
My tc30 also does it when I check the fluid after I use it
   / Front axle pressurized? #4
I just checked the fluid in my JD 870 yesterday and in did the same thing. Hope somebody knows the answer cause I don't. :)7
   / Front axle pressurized? #5
Sounds to me that there is no breather tube.
That, or if one is instaled, it is plugged up.
Plugged tube could cause seals to blow out.
Often a ball check valve thingy, or spring loaded relief device.
My tractor uses a tube that terminates near top of the radiator (so as to not ingest water).
   / Front axle pressurized? #6
Must be normal. My CCY 2400 does the same.
   / Front axle pressurized? #7
This is an example of why it is so important to fill only to the full mark on the dipstick and not all the way to the top. If you have no air space in the front axle housing, something will blow when it heats up.
   / Front axle pressurized? #8
My Son's JD doesn't have a vent. He's replaced seals twice. It still starts leaking after a few hours of hot work. Remove the cap and it releases a lot of pressure. Poor design. All gearboxes should be vented.
   / Front axle pressurized? #9
There are sintered teflon vents that will allow gas to go thru but block water. There are also designs that allow breathing but exclude water by gravity.
larry
   / Front axle pressurized? #10
If you open the cap when the fluid is hot ( air escapes ) and then
replace it again , the air pressure will not be above atmospheric
again . Don't open when cold or it sucks in air again ;)
2015 Ford F-550 Enclosed Service Truck with Liftgate (A53422)
2015 Ford F-550...
Guard Rail Pieces (A51692)
Guard Rail Pieces...
2002 WACKER RD25 ROLLER (A54607)
2002 WACKER RD25...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
2014 10ft T/A Dump Trailer (A51691)
2014 10ft T/A Dump...
2016 GMC SIERRA 3500 SERVICE TRUCK (A51406)
2016 GMC SIERRA...
