Self stopping water fill nozzle?
   / Self stopping water fill nozzle? #1
zmoz
Outside of Raleigh, NC
I frequently find myself filling 55 gallon drums with water from the hose inside my barn, which is very low flow and takes about 20 minutes to fill. I inevitably wander off only to come back to the drum overflowing all over the floor making a muddy mess. I'd really like to be able to turn the water on and just leave sometimes.
What I need is basically a nozzle like they have at the gas station that stops when the tank is full. Does anybody sell something like that meant to be used with a water hose?
   / Self stopping water fill nozzle? #2
Not exactly what you're looking for but you could just put a quick disconnect on your hose and one on a float from a watering trough then hang the float on the barrel. Assuming it's an open top barrel that is. :)7
   / Self stopping water fill nozzle? #3
Most cell phones have a timer feature.
Set it for 15 minutes and wander off ... get back just in time.
Another option is a sprinkler timer, I have seen spring wound ones in lawn & garden departments.
   / Self stopping water fill nozzle? #4
I like this idea the best in case he wanders off too far (e.g. sitting on the throne with a good book :laughing:) to get back in time.
   / Self stopping water fill nozzle? #5
There are lots of different float type valves out there. Check out the ones used for cattle like mentioned above. There are small ones used in RO systems also. There are also electronic ones but you really do not need one of those. A valve would be much nicer than a timer because you could be busy with something for hours and not have to worry about it.
Ken
Unfortunately these are closed top drums so I would need some sort of float valve that fits through the bung opening. A timer would be better than nothing, but, I would really like it to end up exactly full, no more, no less, and the amount of time that takes can vary with my water pressure. Actually it would be nice if I could turn it on when I'm leaving and come back to a full drum the next day.
A normal fuel nozzle like this would be perfect:
Northern Industrial Automatic Shutoff Fuel Nozzle | Fuel Nozzles | Northern Tool + Equipment
...but $50 + shipping is a bit much for what I want, and it doesn't need to be fuel rated...
How do those nozzles work? Maybe I can rig something similar up...
   / Self stopping water fill nozzle? #7
Go look at the float valves for livestock. They just have the water inlet, a metal tube for the water inlet and a float with a rubber seal to stop the flow.
When the metal case on my float valve wore out, I just made a fiberglas unit using some of the parts. I then made another unit using my own parts.
For your task, I would use a water inlet with the tube inlet. This tube end is sharpened to make a good seal. Place this in a PVC pipe. Make a float that rides up in the PVC pipe with a rubber piece on top to make the seal.
Now you turn on the water. The float rides up the PVC pipe. When the rubber seal contacts the sharpened tube it seals and cuts off the water. You just set the PVC pipe to what ever water level you want.
This is kind of hard to explain but if you look at a float valve and see how it works, you will see what I mean. I am thinking outside the box but I think I can make one of these float valve. This may work. The cost to make would be very low.
Just thinking.
   / Self stopping water fill nozzle? #8
I looked for the old valve that I made but could not find it. I did find an old float. This will illustrate how this valve works. The tube is a copper tube that I beveled at the end to a fine point. The rubber disc on the float is 1.25" D so a small valve can be made. For this particular valve the most critical part is that the pivot point is placed so the rubber disc and the tube meet at a right angle. This will provide the best seal.
As the water rises the float will move up and the seal will contact the tube. This will start sealing the water flow. As more water rises more pressure is placed on the float. Eventually the rubber seal cuts off all water flow. It does not take a lot of pressure to stop the flow.
IIRC, when I made my valve I used a metal cap that fit the end of the hose. I drilled a hole in the cap to pass the tube. I made this a tight fit and then sealed the hole edge so no water passes. Then I just made the housing that holds it all together.
Rethinking this valve idea for your needs, I would make a small pivoting float. Like thin PVC pipe. Seal both ends a grind as much material away from the end caps to make it as light weight as possible. Then you could work this valve in at an angle and then secure the water hose vertical. I think it is possible that this may work. Any way hope this helps and good luck with your project.
   / Self stopping water fill nozzle? #9
You might try Hudson Valve Company, Inc.
I have them on my stock tanks because I am not capable of standing in one place or keep my mind on one thing for more than 2 minutes w/o starting on something else that needs done!
I always run my tanks over every single time I HAD to get one of these! :laughing:
   / Self stopping water fill nozzle? #10
Spectrapure carries small float valves that you could adapt to a quick connect garden hose connection. You could tap the bung hole cover or adapt from the bung hole opening. They are small enough to fit through. I use one in the cap of a 10 gallon carboy.
FLOATS FOR REVERSE OSMOSIS
Ken
2018 KENWORTH T880 DAYCAB (A53843)
2018 KENWORTH T880...
2018 CATERPILLAR 950GC LOADER (A51246)
2018 CATERPILLAR...
2016 Ford F-550 4x4 12FT Landscape Dump Truck (A51692)
2016 Ford F-550...
2015 Ram 3500 4x4 Crew Cab Pickup Truck (A53422)
2015 Ram 3500 4x4...
HYSTER H55VM STRAIGHT MAST FORKLIFT (A51406)
HYSTER H55VM...
