Clearing a new field
   / Clearing a new field #1
POC
Gold Member
Southern Indiana
Mahindra 3215 4x4
This is a field that I *remember* being planted in corn....that was about 30 years ago. Now there are trees, mostly < 4" all over the place. I used the backhoe yesterday to dig some out, but it was almost overkill. I had my nephew with me and we tried using an OLD homemade device, basically a piece of 8" C-channel with a 'V' cut in it and a hole for a chain to be attached. The edges of the "V" need to be ground at an angle so they really BITE into the tree. Then just attach to the draw bar (at a low, safe angle, of course ;) ) and pull for all you're worth! It worked good on < 3" stuff. It also depends on the species of tree, dogwoods and (I'm drawing a blank) trees come up pretty easy. Poplar and cedar, not so easy.
I'm wondering if it wouldn't be easier to use a box blade and drop the tines way down and just go around the bigger trees. Then go back and hoe out the bigger ones.
WHAT SAY YE, OH SAGES OF TRACTOR KNOWLEDGE???!!??? :laughing:
   / Clearing a new field #2
POC-
I'm no sage, just learning as I go. Similar to the boxblade idea you described, I found that my subsoiler works very nicely for pulling stumps that are under about 4 inches in diameter at a foot off the ground. I have been pulling mostly oaks, maples and cherry. Procedure is to run the cutting edge about 18-24" on either side of the stump to hook onto & pull out the outer edges of the rootball, then hook under the trunk & lift. You can develop some real grunt with the 3PH. Only negative is you really have to cut the trunk off real low to the ground so your tires don't ride up on it. This means nothing left above ground to tie onto if this method fails.
-Jim
   / Clearing a new field #4
I cleared an old field of (mostly) spruce trees last fall. The worst ones are the smallest (<1") and the largest (>8"). All the rest I just pushed over with the FEL bucket until some roots popped up, then I lowered the bucket and just pushed the rootball horizontally out of the ground. When I got my toothbar (and, later, my grapple rake) this process became even easier and tore up a smaller area of turf for each tree... the grapple rake was almost essential for the clean-up operation! I have a huge windrow of uprooted trees to burn this winter after snow covers the grass in the field.
BOB
Thanks for the info guys. I hadn't really even though of using the FEL...duh...
I have access to a subsoiler, easier than the box blade...I might give that a try. If it doesn't work, like you said it sometimes doesn't, I can use the hoe to get them out.
I'm going to plow this area, so getting the roots out is going to be a must. I don't guess I have to plow it, but I want to sow some clover or something in it.
For the small trees, < 2" would I be just as well off to bush hog them down and then deal with what little roots they have later? I'm thinking bush hog, then use the box blade to gather up the roots and rocks and such and pull it all off to the side.
Any more ideas?
Thanks guys.
   / Clearing a new field #6
I think what you need is a good grapple if your tractor has enough lift capacity and weight to handle it. (I would say something 35 horse or bigger) My Markham grapple will flat rip up trees by the roots. Trees 4" are simple, the teeth of the grapple will pluck them out of the ground and then you have the advantage of being able to carry them off. I can grapple trees up to 6". I have found a box blade not very good at this, but I do keep it on the back when grappling to help cover up the holes and also to drag any leftover debris.
I do have a 35hp tractor. I DON'T have the $1K+ to add hydraulics and buy a grapple. I know that is the BEST plan, but I'm gonna have to make due with what I have, and can borrow.
   / Clearing a new field #8
You need an old "grub plow", John Deere made them, probably others. They had a big knife in front of the moldboard to cut through stumps & small trees to turn them under. Couldn't find a picture of one. :( ~~ grnspot110
   / Clearing a new field #9
What I did this summer was several stages:
  1. rotary cutter anything that the mower would take (under 1 1/2")
  2. use a chain and grub the bigger stuff (hit or miss up to 4", these will be burned in a pile)
  3. use 2 bottom plow to pull up stumps and turn in the small stuff (this is a pain because it tends to jam up in the plow and requires some work to clear)
the vast majority of mine were in the <2" range (buckthorn/prickly ash bushes) ... the bigger stuff is all on the perimeter and I'm chainsawing that as low as I can and letting nature do its thing (this will let me use the mower to cut shoots and saplings down the road)
That is what I was kind of thinking, but the larger trees are all intermingled with the small stuff. And they are just big enough that I don't want to try them with the rotary cutter.
Thanks for all the input guys.
2016 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A54313)
2016 FREIGHTLINER...
1996 Timpte 46ft Hopper (A55301)
1996 Timpte 46ft...
2016 Big Tex 14LX 14ft 7 Ton T/A Dump Trailer (A50322)
2016 Big Tex 14LX...
2018 Ford Fusion Hybird (A53424)
2018 Ford Fusion...
2018 Dodge Grand Caravan SXT Van (A53424)
2018 Dodge Grand...
UNUSED 30PCS Brown Metal Roof Panels (A53117)
UNUSED 30PCS Brown...
