Grade 5 vs Grade 8 bolts... the hot skinny!
   / Grade 5 vs Grade 8 bolts... the hot skinny! #1
picker77
Gold Member
Central Oklahoma
JD 3032E, dual remotes, TnT, tooth bar, grapple
The more I mess with implements/attachments and tractors the more times I find I need to make choices on the right fasteners to use. So I wanted to pass along a link to a brief but very informative page on the subject. I learned a lot from it, maybe some others will too. BTW, the subject may not be rocket science, but the author actually is a rocket scientist. LOL!
ROCKCRAWLER.com - Grade 5 vs. Grade 8 Fasteners
   / Grade 5 vs Grade 8 bolts... the hot skinny! #2
Very informative, thank you!
James K0UA
   / Grade 5 vs Grade 8 bolts... the hot skinny! #3
Nice article. I like his last sentence..."When in doubt, make it stout!" Hard to go wrong with that advice!
   / Grade 5 vs Grade 8 bolts... the hot skinny! #4
Interesting article, helps to clear up some of the old sayings about the various grades of bolts.
Actually, the difference in strength isn't as drastic as I expected it would be. However, I like the bonus of the nice finish and gold-anodized color of Grade 8 hardware. Could be my imagination, but they also seem to hold up without corrosion much longer than the white-finished Grade 5 stuff.
I used to go to Lowe's or Ace Hardware for nuts and bolts and such, but then Lowe's started packaging fasteners in cute little individual onesies-twosies plastic packs, and ACE even prices them per each. In either case the total price can be a shock if you need a dozen or more. However, I found out a while back that Tractor Supply sells their fasteners by the pound, and simply charge a different price per pound for each grade. Since I use Grade 8 for almost everything, about every time I'm in there for something I stop by the fastener aisle and load up with another two or three pounds in common lengths and sizes. By so doing I've built up a decent inventory of Grade 8 fasteners in my shop without going broke doing it, and they have come in very handy.
   / Grade 5 vs Grade 8 bolts... the hot skinny! #7
Finding anybody who sells fasteners by the pound rather than each was a shock to me. Every hardware store I've ever frequented sells everything besides certain prepackaged sizes individually.
   / Grade 5 vs Grade 8 bolts... the hot skinny! #8
Good information.
Don't forget that there are counterfeit bolts out there too. Usually grade 2 or ungraded made with grade 8 markings. Great way to make 500% profit, as long as you don't mind stuff breaking causing death and mayhem.
You won't find counterfeit USA made bolts...
   / Grade 5 vs Grade 8 bolts... the hot skinny! #9
Informative but not complete. You are at a big box store and choose grade 8 bolts, what nuts and washers do you get?
The nuts and washers should also be grade 8. Unless marked you will be picking up grade 2 or 5 hardware.
What if you are replacing a lower grade bolt with a higher grade, no nut to screw the bolt into, the frame is tapped?
A] You drill out the tap and use the same grade nuts.
B] You use a longer bolt to thread deeper into the blind pocket.
Washers are stamped or CUT from sheet metal. The stamping causes a slight CROWN in the washer, take advantage of the crown by placing the flat side away from the bolt head or nut.
I have found that the chine's nuts and washers much too soft for the bolts.
   / Grade 5 vs Grade 8 bolts... the hot skinny! #10
Picker, Race Brothers is another great place to buy grade 5 and grade 8 nuts and bolts by the pound, and also bulk chain, their prices on chain are cheaper than TSC. in all grades. I dont know if you have a Race Brothers store out there in OK land, but we have several in the area here.
James K0UA
2022 Big Tex 22GN-35BK+5MR 40ft T/A Gooseneck Equipment Trailer (A51691)
2022 Big Tex...
MISC PIPE WRENCHES (A53843)
MISC PIPE WRENCHES...
GRADALL XL4100 IV MOBILE EXCAVATOR (A51406)
GRADALL XL4100 IV...
2014 DOOSAN G25 GENERATOR (A53843)
2014 DOOSAN G25...
2014 PETERBILT 388 (A53843)
2014 PETERBILT 388...
2013 PETERBILT 388 DAYCAB BOBTAIL VACUUM TRUCK (A53843)
2013 PETERBILT 388...
