LD1
Epic Contributor
I have tried explaining it everyway I can with the given examples. I guess the only way to really solve this is to have someone with a carryall hook it up to their tractor with the toplink in the highest position, ballast the front, and start stacking on blocks or whatever for weight until the 3PH can no longer lift the load. And then, do nothing else but change the toplink to the lowest position and see how much weight has to be removed until the 3PH can lift the load again.
Or if someone has a spring scale or load block or whatever to anchor to the ground and hook to the back of an implement like a blade of bushhog and see what the lift force is at carious toplink positions.
If I had a 1k spring scale, I would hook up my bushhog and chain the tail wheel to something it wont lift, and see what the max force is at the top position vs the bottom.
Any volunteers have a large enough spring scale be willing to give this a shot??????
