new holland 69 baler
   / new holland 69 baler #1
radicalbill
Molino, Fl
I have a NH 69 Hay baler that I restored. I baled my first 180 bales this weekend. 100 out of the 180 bales came out misshaped and fell apart. can anyone help? I was told to check the hay dogs what do they do?
   / new holland 69 baler #2
In addition, check the tension on the chamber springs at the back. Also check the Knives sharpness. These balers are prone to put out curved bales, if everything is not set just right. Ken Sweet
   / new holland 69 baler #3
Mis-shaped how? With stings up, are they curved left/right or up/down?
bales are curved left. the knotter works fine. looks like the strings are too far left
the knives are sharp and i had a new one made. the gap is about 1/8 inch. do you know what the gap should be?
   / new holland 69 baler #6
I think 1/8 gap is too much. It may be chewing the hay off on that side and dragging on down the chamber as it ties? How are the wear blocks in the ram? Ken Sweet
what wear blocks are you talking about? i have replaced all the bushings on the plunger assymbly
   / new holland 69 baler #8
There is usually wood or fiber wear blocks that the ram slide on. If the ram does not move left to right or up and down at the point of cutting the hay off. You don't have any play in that area. 1/8 inch is way too much clearance on the blades. Ken Sweet
   / new holland 69 baler #9
Hi from Australia,
Firstly is your chamber clean. If it has rust or is missing the bits of angle iron , more than likely it will cause the bale to drag on one side hence the banana bales. I put the angle grinder right over the surface of the chamber and mine immediately were perfect. Always remember to clean out bales at the end of the season and spray chamber with diesel oil or such to stop the rust
Hope this helps
cheers.
ps does any one have a copy of the 69 users manual for sale or in pdf format.
   / new holland 69 baler #10
G'day as ken said 1/8 "is way too much you need to get the two knives passing each other and then get a bar between the plunger and the wall opposite the knives and pry them together, you don't have to try to move a mountain you only need gentle pressure. You should have no more than 1/16" if not then you need to adjust towards the stationary knife. Also as mentioned check the hay dogs in the chamber and make sure they are springing correctly.
Jon
2007 INTERNATIONAL MA025 (INOPERABLE) (A52472)
2007 INTERNATIONAL...
2012 International Prostar (A57024)
2012 International...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
3pt Hay Spear (A56469)
2019 Toyota Rav4 AWD SUV (A55853)
2019 Toyota Rav4...
