Gem99ultra
Elite Member
snip>I have the opportunity to get a used metal cutting band saw. It's a Duracraft that will likely need some repairs. The guy said it keeps throwing blades and there's some wobble in one of the bearings.<snip.
I've owned my Duracraft for something over 35 years. Cut miles of iron and steel with it. Even cut railroad track for anvils. And yes, occasionally you'll have a blade that wants to keep jumping off. Usually you can correct that with your tensioner.
Mine uses some odd-ball size blades like 58 1/2" or something like that... I've made up my own many times simply by silver soldering one to the correct length. No problem. But I've seen places that will make up your blades also.
One thing that I do is to keep the guide wheels well lubricated during cutting. I use WD40 squirted on them to wash down the filings. Cheap enough and easy enough. I just don't like to see a guide wheel skipping. I keep them set a zero clearance minus a couple of thousandths. May be right or maybe not, but that works for me.
If it's a good deal, I'd chance it. I'd hate to think that I didn't have it around.
