check
Elite Member
- Joined
- Sep 26, 2008
- Messages
- 4,012
- Tractor
- 2009 Kubota BX25
I filled up my portable gas generator tank with diesel by mistake, but did not run it. I assume I have to drain the tank AND the carb and fuel filter now?
I filled up my portable gas generator tank with diesel by mistake, but did not run it. I assume I have to drain the tank AND the carb and fuel filter now?![]()
I'm not a mechanic, but I don't see why a deisel would score up it insides from gas when gas engines don't..
It sounds like its locked up. Aside from lubrication issues the addition of gasoline lowered the octane/cetane level ALOT. I could imagine it was predetonating its buns off till something let go and "stall" no more starty. Hate to say it but im pretty sure your engine is toast, obviously it may not be... Just my guess, but either way have it checked out and best of luck that its something simple like an air pocket, but that wouldnt expkain the stall in the first place :/
The Diesel Mechanic at my local Kubota Dealer said the BX24 in the shop was filled with gas and run till it quit...
Apparently, pre-ignition seized/scored the cylinders and cracked the head from the extra heat.
jake98 said:I'm not a mechanic, but I don't see why a deisel would score up it insides from gas when gas engines don't..
